esantoro Posted June 10, 2007 Report Posted June 10, 2007 What's the best way to set steel tubular rivets and caps? Hit the cap onto the tubular post, or hit the tubular post into the cap. All the presses seem to be set up so that you are pressing the post down into the cap, or if you are peening, you are pressing the post down onto the peening die? Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
esantoro Posted June 12, 2007 Author Report Posted June 12, 2007 Do any of you think a tool like the following would work well in setting tubular and solid rivets in my briefcases? http://www.hansonrivet.com/w82b.htm ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Ambassador Don101 Posted June 13, 2007 Ambassador Report Posted June 13, 2007 i hardly use them but looking at the picture of the setter it looks like a good tool, another way you could probbably set them is if you have a sturdy drill stand and just use it to conpress the rivets by putting a bar in the drill bit and lowering as if you were going to drill, dont turn it on ...just kidding Quote
Members Hoyden Posted July 25, 2007 Members Report Posted July 25, 2007 I put them on my anvil and hit the cap into the post with a rivet setter and my mallet. That seems to work the best and they don't come undone either. Quote
MikeG Posted October 22, 2007 Report Posted October 22, 2007 I've set rivets & snaps with the ol' mallet & anvil, but I have been looking for a better way (I tend to either not get them tight enough or I bend them). I also don't like the way the finished top of the snaps I install show the mark from the stem, deforming the nice round head. I asked a fellow from Tandy, and he told me this was normal, and had no solution to prevent that. Does anyone have any experience with the Standard setter or the Tandy model? Or is the mallet in fact the best way & I should forget the cost of a machine? My thoughts so far: Standard is expensive Tandy is expensive and you have to buy a different head for everything There is another machine called American Tag; don't know if it's a good tool or junk. http://cgi.ebay.com/SETTER-TOOL-GROMMET-EY...1QQcmdZViewItem Thanks for your comments. Quote
Ambassador Beaverslayer Posted October 22, 2007 Ambassador Report Posted October 22, 2007 Mike, What I've done, is depending on the thickness of the leather I'm putting the snap into, I will cut a bit of the stud off. This keeps it from causing that deformation of the button. Ken Quote Beaverslayer Custom Leather<br />Wearable Works of Art https://www.facebook...erCustomLeather
MikeG Posted October 22, 2007 Report Posted October 22, 2007 Thanks - I've been doing that with a Dremel cutoff tool, but perhaps I've just been a little too cautious about cutting too much off. I guess you also recommend using the mallet & anvil. Quote
Ambassador pete Posted October 22, 2007 Ambassador Report Posted October 22, 2007 I just use a pipe wrench with a piece of leather on each jaw and crimp it.I know that there are places where you can't do this but on places that are close to the edge it works fine and doesn't leave any marks. Quote
Ambassador Beaverslayer Posted October 22, 2007 Ambassador Report Posted October 22, 2007 Mike, yep I use a mallet and anvil. Also, I'll trial and error a few before I get the right length of cutting. Ken Quote Beaverslayer Custom Leather<br />Wearable Works of Art https://www.facebook...erCustomLeather
esantoro Posted October 22, 2007 Author Report Posted October 22, 2007 Can you also snip the ends of the thicker (not Tandy) Jiffy rivets made in Belgium and sold by OTB, among others? Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
