Members Firewalker Posted March 24, 2018 Members Report Posted March 24, 2018 Hello there all. I am wanting to make a lift belt for a potential client and this will be my first one. Has anyone made them before and if so, what weight leather would you recommend? This will be long enough to fit a 60" waist so buying off the rack is not an option. I am thinking two layers of 12 oz would be thick enough. I am planning a 3" buckle / belt with it widening to 6" across the back. Any advice is always appreciated. Thanks in advance! Scott Quote Follow me here ---> https://www.instagram.com/campbell_leatherworks/
Contributing Member JLSleather Posted March 24, 2018 Contributing Member Report Posted March 24, 2018 These are generally a single layer of 13/15 oz, or two layers of 8 oz. MORE than enough. BRIDLE works great, since it wont absorb the sweat. If you want to carve / stamp it, I'd go with an inner layer of bridle and outer layer of tooling leather. And I've made them 6" wide for the CONFUSED when they specifically request that, but it's pointless really, 4" is "normal". Unless the guy is quite tall, I stick to 4" wide. (The guys who REALLY work out will tell you that the belt is for your ABDOMEN, not your back. The width is to SPREAD THE PRESSURE out when your AB MUSCLES FLEX, preventing hernia) IF you go with two layers, be sure to put a bit of curve in when you glue the layers - not flat on the table. Looks nicer, more professional, and most say it's more comfortable to use (inside is smooth). And finally, my PERSONAL preference -- much as I like tooled leather, I think it's easy to OVER DO tooling on these. Less is more. Here's one way, if it helps, have atter ... http://www.jlsleather.com/wp-content/uploads/2015/09/WB4.pdf Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Firewalker Posted March 24, 2018 Author Members Report Posted March 24, 2018 6 hours ago, JLSleather said: These are generally a single layer of 13/15 oz, or two layers of 8 oz. MORE than enough. BRIDLE works great, since it wont absorb the sweat. If you want to carve / stamp it, I'd go with an inner layer of bridle and outer layer of tooling leather. And I've made them 6" wide for the CONFUSED when they specifically request that, but it's pointless really, 4" is "normal". Unless the guy is quite tall, I stick to 4" wide. (The guys who REALLY work out will tell you that the belt is for your ABDOMEN, not your back. The width is to SPREAD THE PRESSURE out when your AB MUSCLES FLEX, preventing hernia) IF you go with two layers, be sure to put a bit of curve in when you glue the layers - not flat on the table. Looks nicer, more professional, and most say it's more comfortable to use (inside is smooth). And finally, my PERSONAL preference -- much as I like tooled leather, I think it's easy to OVER DO tooling on these. Less is more. Here's one way, if it helps, have atter ... http://www.jlsleather.com/wp-content/uploads/2015/09/WB4.pdf Hello there and thank you for the reply. I must say that is the most information packed reply I could imagine and I really appreciate the information. You are always eager to share your knowledge and I really admire that. I do agree with you on the real reason for the belt and giving you something to push against. I can see how putting the curve in it would make it more comfortable as well. I originally was thinking of doing two layers flesh to flesh side cemented to give a smooth edge on the inside and adding some suede for grip. I want just a little bit of grip but don't really want to make a sweat sponge. Would you just stack them flesh to grain and leave the flesh for the "grip". (in the example of using bridle leather) I figured if it is suede there is only so much sweat that can be absorbed and the next layer would be sealed grain side. What would you recommend? I hope I am getting my point across clearly. Thanks a million for the interest. Scott Quote Follow me here ---> https://www.instagram.com/campbell_leatherworks/
Contributing Member JLSleather Posted March 24, 2018 Contributing Member Report Posted March 24, 2018 Flesh to flesh, leave inside smooth. Bridle grain side to the inside, just buff (no finish needed). The belt in teh pic got 3 light coats of neatsfoot, couple days apart, otherwise no "finish". Each his own. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Leatherhips Posted March 24, 2018 Members Report Posted March 24, 2018 Hi, In case useful, take a look at this supplier of powerlifting belts - https://titansupport.com/product-category/powerlifting-belts/titan-longhorn-belt/ Many moons ago I used to compete & a lot of powerlifters preferred the suede or flesh lining, not so much for the sweat aspect, but more so it didn't slip around on top of clothes. Andy Quote
Members Firewalker Posted March 25, 2018 Author Members Report Posted March 25, 2018 8 hours ago, JLSleather said: Flesh to flesh, leave inside smooth. Bridle grain side to the inside, just buff (no finish needed). The belt in teh pic got 3 light coats of neatsfoot, couple days apart, otherwise no "finish". Each his own. Thank you very much. I was able to get them to go down to a 3"-5" but was set on it. You did a nice job on that one you shared. Nice indeed! 7 hours ago, Leatherhips said: Hi, In case useful, take a look at this supplier of powerlifting belts - https://titansupport.com/product-category/powerlifting-belts/titan-longhorn-belt/ Many moons ago I used to compete & a lot of powerlifters preferred the suede or flesh lining, not so much for the sweat aspect, but more so it didn't slip around on top of clothes. Andy Hi there Andy. That's what I was wondering about. It's been a while since I had a deadlift bar in front of me. I appreciate the interest Quote Follow me here ---> https://www.instagram.com/campbell_leatherworks/
Members bgl500 Posted March 26, 2018 Members Report Posted March 26, 2018 On 3/24/2018 at 9:20 AM, JLSleather said: These are generally a single layer of 13/15 oz, or two layers of 8 oz. MORE than enough. BRIDLE works great, since it wont absorb the sweat. If you want to carve / stamp it, I'd go with an inner layer of bridle and outer layer of tooling leather. And I've made them 6" wide for the CONFUSED when they specifically request that, but it's pointless really, 4" is "normal". Unless the guy is quite tall, I stick to 4" wide. (The guys who REALLY work out will tell you that the belt is for your ABDOMEN, not your back. The width is to SPREAD THE PRESSURE out when your AB MUSCLES FLEX, preventing hernia) IF you go with two layers, be sure to put a bit of curve in when you glue the layers - not flat on the table. Looks nicer, more professional, and most say it's more comfortable to use (inside is smooth). And finally, my PERSONAL preference -- much as I like tooled leather, I think it's easy to OVER DO tooling on these. Less is more. Here's one way, if it helps, have atter ... http://www.jlsleather.com/wp-content/uploads/2015/09/WB4.pdf JLS is pretty much correct. The purpose of a belt is to give your abdominal muscles something firm to press against to aid in building abdominal pressure and a rigid torso which is what helps to protect the back. Most flimsy belts you see in commercial gyms are useless. The two most common thickness belts are a 10mm (That's what I use) and a 13mm. It's a personal preference thing but I'd venture to say most average lifters would be fine with 10mm. My belt has the flesh side exposed on both sides although I've seen plenty of belts with the smooth side on outside of the belt and flesh on the inside. For some more reference here is a link to the belt I use: http://www.inzernet.com/detail_belt.asp?PRODUCT_ID=FOREVERBELTS_BUCKLE10MM Quote
Contributing Member JLSleather Posted March 26, 2018 Contributing Member Report Posted March 26, 2018 Actually, that's not "flesh side out" -- that's somebody selling you SPLIT leather (the grain is gone). It's cheaper, so their margin is higher. Each person does his / her own thing - no matter to me - but anybody says he can alter 1/4" of leather by flexing his abs (with weight or without) is WAY 'full of it'. I don't know how a belt would "slide" or "move around" either, long as we're on that. A belt - once tightened - could only possibly move to a part of the body which is SMALLER than where it is put on. So the only person who would have a belt MOVING on them, would be the one whose waist is larger than the area above or below it. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Firewalker Posted March 29, 2018 Author Members Report Posted March 29, 2018 On 3/26/2018 at 8:38 AM, bgl500 said: JLS is pretty much correct. The purpose of a belt is to give your abdominal muscles something firm to press against to aid in building abdominal pressure and a rigid torso which is what helps to protect the back. Most flimsy belts you see in commercial gyms are useless. The two most common thickness belts are a 10mm (That's what I use) and a 13mm. It's a personal preference thing but I'd venture to say most average lifters would be fine with 10mm. My belt has the flesh side exposed on both sides although I've seen plenty of belts with the smooth side on outside of the belt and flesh on the inside. For some more reference here is a link to the belt I use: http://www.inzernet.com/detail_belt.asp?PRODUCT_ID=FOREVERBELTS_BUCKLE10MM Thanks for the reply and I too agree on the true purpose of the belt. I have gotten familiar with many of the more respected belt makers in the mass produced world. It seems the bulk of them are using sole leather in varying thicknesses and suede on the inside and outside. I think the suede is simply to get a vibrant color that gives it some pop while it would give a certain amount of grip on the inside. I appreciate your reply. Quote Follow me here ---> https://www.instagram.com/campbell_leatherworks/
Members Firewalker Posted March 29, 2018 Author Members Report Posted March 29, 2018 On 3/26/2018 at 10:35 AM, JLSleather said: Actually, that's not "flesh side out" -- that's somebody selling you SPLIT leather (the grain is gone). It's cheaper, so their margin is higher. Each person does his / her own thing - no matter to me - but anybody says he can alter 1/4" of leather by flexing his abs (with weight or without) is WAY 'full of it'. I don't know how a belt would "slide" or "move around" either, long as we're on that. A belt - once tightened - could only possibly move to a part of the body which is SMALLER than where it is put on. So the only person who would have a belt MOVING on them, would be the one whose waist is larger than the area above or below it. I did decide to follow your recommendation on the bridle inside and veg tan outside so I can tool it. It will be a very basic tooling but one that is important to him. The scenario you describe with it moving will be possible in this particular build. I was able to convince them of doing a 5" back and it will be 3" on sides and front. On the coloring I am shooting for Michigan colors Navy and Maize. I have a eco flo dye that is amazing in color but I am about over using water based dyes. I didn't see it available in the fiebings pro dyes and don't think it would be smart to use water based dye in a sweaty situation. Do you know of anything that will permanently lock in the color of water based and prevent it from rubbing off on clothes? That guitar strap gave me a run for the money trying to get that figured out. Thanks again for the interest. Scott Quote Follow me here ---> https://www.instagram.com/campbell_leatherworks/
Members bgl500 Posted March 29, 2018 Members Report Posted March 29, 2018 Looking forward to seeing your finished belt Firewalker. Maybe use it as some inspiration to make my own belt. Cheers. Quote
Members Firewalker Posted March 31, 2018 Author Members Report Posted March 31, 2018 On 3/29/2018 at 7:07 AM, bgl500 said: Looking forward to seeing your finished belt Firewalker. Maybe use it as some inspiration to make my own belt. Cheers. I will be happy to share the finished project with everyone. Cheers amigo Quote Follow me here ---> https://www.instagram.com/campbell_leatherworks/
Contributing Member JLSleather Posted November 5, 2019 Contributing Member Report Posted November 5, 2019 Ooooo, ... can this be called "revisiting"? Always wanted to "revisit" something ... Had a gal call about a belt.... pro power lifter bikini thing So we were discussing how to make her belt, I had a few "moments" ... making me think a little. Check on line, or any of the big box stores, and you see lifting belts [most often] sold in 10mm or 14mm thickness. WHAT THE ...@?!@! That's HALF AN INCH of leather.. FOR WHAT?@! Exactly WHAT do you think you'll do that will allow you to flex the abs so forcefully that you need that much leather? EVEN IF you could ever find a way to exert that type of force, you'd die anyway. Actually, you'd pass out long before you ever got there, so the conversation is pointless. Did I mention bikini? No, wait.. FOCUS... So I suggested that 1/4" thick is WAY more than enough. She wants smooth, and pretty, and a bit luxurious feel - which is why she called me. Those belts in the stores are likely fine if you need a strap to pull your truck out of the snow or mud. Think more 5'7", 135 lb, bikini, deadlifts. If you can. So - the point? She likes those lever buckles, or at least wants one this time. I had never actually thought of it before - but the prongs on that lever buckle are going to protrude through an 8mm belt. Not much, but enough to catch skin in there. This gal doesn't have much "skin" loose to grab, but I think we'll need to do something there. Sadly, I did a lw search for 'weight lift" and all I got was already me I actually had an ad - I see it's expired now - that says if you want a standard piece of leather, sew some suede on it and make it look "passable", then you should head to Dick's or Scheels instead of calling me. That $30 P.O.P. on the shelf will do what you need just fine. But I don't make that 15 minute "click out another one" stuff (tell the truth, some reading this DO - then they spend 2 hours making a video and call it a 2:15 project. No matter, not my problem). Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Contributing Member JLSleather Posted November 5, 2019 Contributing Member Report Posted November 5, 2019 On 3/24/2018 at 4:10 PM, Leatherhips said: a lot of powerlifters preferred the suede or flesh lining, not so much for the sweat aspect, but more so it didn't slip around on top of clothes. See, THIS I don't git at all. WHERE would it go? How can it "slip" if you're wearing it? Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Contributing Member fredk Posted November 5, 2019 Contributing Member Report Posted November 5, 2019 The thickness of the leather helps prevent hernia during the weight lifting. Quote Al speling misteaks aer all mi own werk..
Contributing Member JLSleather Posted November 5, 2019 Contributing Member Report Posted November 5, 2019 2 hours ago, fredk said: The thickness of the leather helps prevent hernia during the weight lifting. Not true, but I agree that's often the story that's told. Want to test the theory? If it takes 3/8" of leather to prevent "blow out" while straining (lifting heavy something), then you should be able to distort an 8 oz [3mm] strap by flexing your abs. Let us know the link to the video showing us how you did.. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
CFM chuck123wapati Posted November 5, 2019 CFM Report Posted November 5, 2019 6 hours ago, fredk said: The thickness of the leather helps prevent hernia during the weight lifting. Also prevents the belt stretching out of shape during the lifetime of the belt, folks want these things to last years and look badass at the same time, wimpy belts just aren't badass looking lol. But if I'm trusting my health and safety to this thing I would opt for thicker , to a point, any day. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Contributing Member JLSleather Posted November 5, 2019 Contributing Member Report Posted November 5, 2019 1 minute ago, chuck123wapati said: Also prevents the belt stretching out of shape during the lifetime of the belt, Well, no point spending significant time debating/arguing the point really. But seriously -- measure the length of the belt. Go pull a truck with it for a while. Measure it again. Divide the amount of stretch by the pounds per square inch of tension.... no wait.. that would NOT be accurate, cuz with a belt you want to measure the stretch by PUSHING FROM INSIDE OUT. So just stick with that... show me the guy who can stretch a 1/4" thick belt AT ALL, and I'll let it go TWICE I told people you buy the belt at full price. If it stretches, bring it back and I'll GIVE you one, FREE of charge. I haven't heard from either of those people Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
CFM chuck123wapati Posted November 5, 2019 CFM Report Posted November 5, 2019 16 minutes ago, JLSleather said: Well, no point spending significant time debating/arguing the point really. But seriously -- measure the length of the belt. Go pull a truck with it for a while. Measure it again. Divide the amount of stretch by the pounds per square inch of tension.... no wait.. that would NOT be accurate, cuz with a belt you want to measure the stretch by PUSHING FROM INSIDE OUT. So just stick with that... show me the guy who can stretch a 1/4" thick belt AT ALL, and I'll let it go TWICE I told people you buy the belt at full price. If it stretches, bring it back and I'll GIVE you one, FREE of charge. I haven't heard from either of those people you have good points about the thickness and I agree to a point, these belts also deal with heat and sweat as well as the pressure of the work , we both know what heat and water will do to leather they also have to do this work for years not just one time. BUT the biggest thing they do is keep you safe and free of injury, they are safety equipment bottom line. But here ya go a belt made for me that didn't last a year its 3mm what you wanted to see on your video it lost 1/2" in width in just a few months doing nothing but holding up my pants and being pushed from the inside out. To me if a customer with a 60" waist wanted a 1/2" thick belt I would make it simply for the safety factor and unknowns about just how extreme this person would be on it, that's one big dude. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Contributing Member JLSleather Posted November 6, 2019 Contributing Member Report Posted November 6, 2019 Not all leather is created equal, I'll give ya that Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
CFM chuck123wapati Posted November 6, 2019 CFM Report Posted November 6, 2019 1 hour ago, JLSleather said: Not all leather is created equal, I'll give ya that Sure isn't Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
