Full disclosure. This radio strap is not my work. But rather a picture that I pulled off facebook.  My question is, how do you do the fine painting. Like the white outlining on the letters. Or the flag for that matter. Or the superfine maltese cross and lettering at the bottom.  When I try to do white outlines on my letters my brush is too wide and even the paint drop on the end of my brush is too wide. And I get it splashed over the edge. I even tried to thin the paint and flow it into the channel created by the stamp. But even then it doesn't flow evenly. What's the trick?
Buy some small 1 oz squeeze bottles with needle tips.  Put the paint in and apply through the needle tip - pretty easy to do precise painting this way.  I bought some at Amazon: 6pcs 1 Oz. Multi Purpose Precision Applicator Squeeze Bottles+ 16 pcs Needle Tips+ 6pcs Needle Tip Caps but they no longer sell this type.  But you should be able to find similar bottles.
Gary
Cowboy 4500, Consew 206RB-4
Try gel-ink pens for the fine work
Gary
I second the needle tip bottles. I'm pretty sure I am closing in on 2k radio straps painted with them. Bonus points for not ever having to dip a brush into paint... just squeeze.
Rob
www.ridgewayleatherworks.com
IG: @Ridgewayleatherworks
FB: RidgewayLeatherworks
I occasionally have had to do fine detail painting like this with a brush, but I'm intrigued by the idea of the needle bottles.  I'm assuming your using acrylics?  If so, what kind?
Thanks in advance,
Bob
There are always possibilities....
Bob Blea
C and B Leathercrafts
Fort Collins, CO
Visit my shop at http://www.etsy.com/shop/CandBLeather?ref=si_shop
Instagram @bobbleacandbleather
Thanks in advance,
Bob
Bob, I use Angelus and Giardini as well as some cheap acrylic paints I bought at Walmart - I dilute all of them with about 20% distilled water so they flow out the small tips.
Gary
Easy to outline the letters and the scrolls underneath using the squeeze bottles
That looks really nice!  I'm going to have to give this a try.
Bob Blea
Fort Collins, CO
Thanks in advance,
Bob
Angelus almost exclusively. I have needle tips ranging from 18 gauge to 25 for the type of detail i'd like to do.
Rob
Thanks for the into, your techniques are clearly working very well for you!  Your work is very impressive.
Bob Blea
Fort Collins, CO
