Members Jerdav73 Posted April 4, 2018 Members Report Posted April 4, 2018 Looking for some advice! I'm working on refurbishing a Singer 29k51 patcher. I cannot seem to get the foot presser down far enough to press on the material. When I let it down it still remains about 1/4 inch above the material I'm working with. Any suggestions. I have tried tapping it down, with a hammer, and that does seem to depress it on top of the material, but then the foot doesn't "walk" along the material. Do you think it could be so dirty? THANKS FOR ANY SUGGESTIONS Jerdav73 Quote
Members Constabulary Posted April 4, 2018 Members Report Posted April 4, 2018 (edited) Could be dirt or maybe something wrong assembled. Please post good clear and detailed pictures of your machine from front and back (head only) and when you have the chance post a video too. It is a wild guess but is it possible that the tip of the bell crank lever does not sit in the ring grove of the feed motion ring slide bar? I guess you have this parts list already, right? SINGER 29K51,29k56.pdf Edited April 4, 2018 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted April 5, 2018 Members Report Posted April 5, 2018 Might be the foot height adjustment in the back. If not assembled correctly, it can stay up. glenn Quote
Members Jerdav73 Posted April 5, 2018 Author Members Report Posted April 5, 2018 13 hours ago, shoepatcher said: Might be the foot height adjustment in the back. If not assembled correctly, it can stay up. glenn Glenn, Thanks for the reply. I'm not too certain where the foot adjustment is located in the back. I've adjusted the tension spring in the back from very loose to very tight, but that doesn't really bring the foot down. When I let the foot down it still remains too high, about 1/8 inch. I can slip a piece of leather under it without even raising the foot. By tapping with a hammer on the top of the rod in the back that holds the long spring assemby, I can bring it down on top of the material, but this should happen freely, not with me tapping. I'm thinking that the foot isn't the problem, but that something is restricting the entire assembly from descending. I'm going to check tonight to see if there is some type of foot height adjustment in the back as you suggest. Again, thanks, and I'll let you know if I'm Successful. Jerry Quote
Moderator Wizcrafts Posted April 5, 2018 Moderator Report Posted April 5, 2018 Jerry; Does your machine have a long torsion spring along the back, with a thumbscrew adjustable sliding block on the head side of it? If so, check that sliding block to see if somebody has added material to the top of it. The top of the block makes contact with a lever, which is what determines the amount of lift of the foot as you sew. The lift is increased by moving it towards the flywheel and decreased by moving it towards the head side. There needs to be a little clearance between the top of the block and the lever that lifts the foot. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members shoepatcher Posted April 5, 2018 Members Report Posted April 5, 2018 Jerry, Send us a few pics of the back of the machine. We meaning Wiz, Constabulary or myself) can better tell you what to do once we see the back of the machine. glenn Quote
Members Jerdav73 Posted April 6, 2018 Author Members Report Posted April 6, 2018 I've attached some photos of the top of my singer 29k51. I've worked and worked at trying to find what is restricting the foot from pressing firmly on the plate - one of the pictures indicates how far above the sewing plate the foot lies. I'm now suspecting trouble withn the bell crank assembly but I'm not about to venture into territory where I shouldn't be. Thanks again in advance for any advice. Jerry Quote
Members Constabulary Posted April 6, 2018 Members Report Posted April 6, 2018 (edited) Remove the tension thumb nut then losen the 2 nuts I have marked in your picture and reposition them as shown in the 2nd picture. Meaning - try to find the point where the foot meets the needle plate. Tighten both nus properly when done. Your upper nut is thinner than the one in my picture so the threaded end that sticks at the top should be approx 6-7mm. Thats at least how mine is positioned and it works well. Furthermore the machine seems to need a thorough cleaning this for sure will help to improve the performance. Hope this helps - if not report back. EDIT: BTW - your top nut is not the original one - the original nut is a bit higher (see my picture) Edited April 6, 2018 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Constabulary Posted April 6, 2018 Members Report Posted April 6, 2018 Another hint - please show some pictures of your thread length adjuster - maybe the "gib" is missing... The position of the gib and the squared piece is important too. Just another guess. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Jerdav73 Posted April 6, 2018 Author Members Report Posted April 6, 2018 I'm certain that the gib is in place - it may be a bit worn but it alters the length of the stitch so I assume it's OK. Also, how about a tip on cleaning the machine. Is kerosene and elbow grease my best option? Quote
