1 minute ago, ABHandmade said:
This is all my bad English :)
I was really interested in whether the beveling was used without a cut. Because I did not see the traces of a cut on the runes.
Mike confirmed that this is the case.
Thank you!
Do you see traces of a cut anywhere else?
Learnleather.com
Clearly expressed - no. But on the runes there is clearly a very smooth difference in heights, which is usually achievable only in the case when the leather is not cut. I wanted to check if my guess is correct.
Ok good.  I thought I was slipping!
Learnleather.com
It is exactly that I do not see any obvious traces of the leather cut and caused my admiration for your professionalism.
Edited by ABHandmade
