My singer 111w153 runs well and seems to be adjusted correctly. I still have random dropped/skipped stitches.
Alredy done
Verified timing
adsusted feet
changed and checked timing belt
changed take up bell crank
cleaned and adjusted tension plate
verfied bobbin tension
adjusted sewing hook guide latch
New belt and adjusted clutchmotor
still at a loss as to my problem. Could be:
thread/needle size
timing not right with needle bar
IDK...
please help
Needle bar to high or too low? Hook too far away from needle? Hook tip should meet the center of the needle ~1.6mm above the needle eye. Hook tip should be as close as possible to the needle but should not touch it.
Do yo you have a manual? Most standard adjustment procedures are well described in the manual.
Singer Class 111 Instructions.pdf
Edited by Northmount
Uploaded file
I have manuals; PDFs from internet. Don’t have the rig marks on the needle bar, but from what I’ve adjusted it seems correct. Your link is not working.
i think the hook needle spacing sounds like a good place to check. Changed needle size so seems reasonable
thanks and I’ll post results
when you have a manual already I don´t have to upload it again ;) Nothing new in my PDF.
When the machine is correct set you can use #100 - #140 needle (metric) w/o making hook adjustments - at least I don´t have to.
I cross  referenced the spacing with the consew and Juki manual.  That is definitely something I have not checked,  and that seems like it very easy adjustment. The machine is running great and smooth. It’s just that In about a 10-15 inch run it will skip 1 to 2 stitches. Additionally it’s good information to know that if you change the needle significantly, you need to change the hook position.  When I bought the machine it had a very large needle in it probably 20+  I downsize the needle to between 16 and 18 and that could’ve easily thrown that off. I also think that my needle guard washer  is not properly Adjusted. I will definitely post results so as to help anyone else
8 hours ago, Constabulary said:
Needle bar to high or too low? Hook too far away from needle? Hook tip should meet the center of the needle ~1.6mm above the needle eye. Hook tip should be a sclose as possible to the needle but should not touch it.
Manual is a bit blurry as I had to scale down the file.
Singer-Class-111-Instructions.pdf
I'd like to see the manual.  Is there a way to post it to Dropbox or something so you don't have to scale it down? I could give you a Dropbox folder to put it in.
Can you take a video or close up pics of the needle and hook as the hook pics up thread?  The gap between needle and hook should be as close to nothing, zero, zilch as possible.
thanks.  Is there a link or way to get the entire manual? I have  155 that I need to do a total adjustment to.
I think I got it!!! I adjusted the hook position, and re adjusted the hook latch. Better but still skipping. Upped the needle size. Still skipped, watched the functions very closely... I had put on a new foot it seemed to contact you the needle. Put on the old center foot VOLA! full 8” runs 20+ times without a hitch
may widen the hole on new center foot or it may be too tall, all I know is it’s working great now w/ old center foot and new outer foot
Thanks for all y’all help, and I hope this helps someone else too:)
A quick search should turn up a thread that's full of all sorts of singer manuals.
