Members dikman Posted June 25, 2018 Members Report Posted June 25, 2018 I've finished the book (sob! I want to read more!) and have a couple of questions. He refers to the most common types of leather used as bridle and skirting. I gather that skirting is the heavier type but how does it relate to what we use today, as in what weight would the two types be? In most cases it appears that holsters were normally a single layer of leather (unlined) so would they have been fairly soft (by our standards, where we generally make rigid holsters)? The book cleared up a few mis-conceptions I had about the Mexican Loop holster, and I had a bit of a chuckle at some of the old posed photos. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Contributing Member fredk Posted June 25, 2018 Contributing Member Report Posted June 25, 2018 1. Bridle leather is dyed thru and waxed on both sides so its smooth. Its usually about 3.5mm thick. Not necessarily 'soft' but more supple. Not too good for tooling or carving 2. Skirting leather is heavier/thicker at [usually] 4 - 4.5mm minimum, also dyed thru, but finished only on the grain side. Its stiffer than Bridle. Its good for tooling/carving and wet moulding Both are available as such from tanneries, but Skirting is more akin to your regular tooling/carving leather #1 would have been used on holsters which would get rough treatment and not much looking after care #2 would be used on the tooled/carved holsters were the owner would tend to look after it better NB; remember, in the 1880s/1890s a drover earned $13 to $18 a month. A basic cheap Mexican Loop holster cost about $2. Thats about 3 or 4 days wages. He would look after that holster Quote Al speling misteaks aer all mi own werk..
Members dikman Posted June 25, 2018 Author Members Report Posted June 25, 2018 Thanks fredk, so the major difference between the old skirting and what I get is it's pre-dyed. That would account for the fact that most of the old leatherwork is all the same colour as I guess it would make life simpler for the saddlers. Is skirting a particular cut of the hide, or is it simply a term to denote how the hide is treated (which is what it sounds like to me)? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Contributing Member fredk Posted June 26, 2018 Contributing Member Report Posted June 26, 2018 afaik 'skirting' is treated so its much stiffer than regular tooling leather. I have some thick side from Le Prevo and its very supple, a thinner piece I picked up [but did not buy] at Tandy was almost as stiff as a board. I guess that piece at Tandy would be like 'skirting' Quote Al speling misteaks aer all mi own werk..
Lobo Posted June 26, 2018 Report Posted June 26, 2018 Saddle skirting is typically very thick vegetable-tanned leather, 12-oz to 15-oz or so. For those who need a point of reference, one ounce in leather weight equates to approx. 1/64" in thickness. You will seldom see cowhide any heavier than what is commonly referred to as saddle skirting. When shopping around it helps to keep in mind that "gauged" leather weight is usually within a range of tolerance, and there will be variations throughout the hide, side, shoulder, back or other cut being offered. Any leather other than vegetable-tanned is generally unsuitable for use in holsters. Any veg-tanned leather that has been infused with waxes or other treatments is generally unsuitable for use in holsters. Quote Lobo Gun Leather serious equipment for serious business, since 1972 www.lobogunleather.com
Members Treed Posted June 26, 2018 Members Report Posted June 26, 2018 Something else to consider is the time period. Good hides were shipped by wagon and not overnight air or truck.... the majority of work by a leather worker was in repair and building of saddles, harness and other items needed for transportation, work and necessities of life. Holsters were a tool to hold a handgun.... just a pocket, something that didn't need to be strong, but needed to be durable. The hides were cut to provide the most with little waste, and by the degree of strength to the items needed. Harness, reins and other items that need the greatest strength and durability came from the back. Saddle parts and items such as horse collars, bridles, halters, etc. were from the middle of hides. The leather left over was the bottom or bellies of the hides. The softer and more flexible leather...... If you can get ahold of or inspect any large quantity of ture period holsters you will see how soft and pliable the leather is. Course time and age will apply here also..... but you will find that the grain is not as tight in period holster as in period harness or saddles. Holsters with tooling will not be as pronounced as that in saddles of the same time period, which I believe is from the use of the softer leather.... Remember that during this time period there was not the machinery that we have to day to split an finish leather coming out of the tanneries. Those variations that Lobo talks about would have been more pronounced during that time period than what we see today. Bobby Quote Bobby Rose Rock'n R custom holsters
Members dikman Posted June 26, 2018 Author Members Report Posted June 26, 2018 Thanks Bobby, that's exactly what I wanted to know. Not having access to old original holsters is why I asked, as the photos obviously can't show how the leather actually performs. By the way, would these saddlers have had any type of stitching machines, or was it all done by hand? And what size thread would they have used relative to our sizing system? In the photos some of them look like they've been sewn with fairly fine thread (#138 ?). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members plinkercases Posted June 26, 2018 Members Report Posted June 26, 2018 here is a good reference site on vintage holster making etc. https://www.vintagegunleather.com/ Quote "Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691 plinkercases.ca
Contributing Member fredk Posted June 26, 2018 Contributing Member Report Posted June 26, 2018 10 minutes ago, dikman said: By the way, would these saddlers have had any type of stitching machines, or was it all done by hand? And what size thread would they have used relative to our sizing system? In the photos some of them look like they've been sewn with fairly fine thread (#138 ?). Most assuredly yes. Singer originally made his sewing machines for harness makers. If you look carefully at a number of the holsters you can tell which ones have been sewn on a machine. A great many holsters were made in bulk and sold by mail order direct to customers and to retail outlets. Only by sewing on a machine could a supplier be able to offer them at a cheap price 'by the dozen'. The military holsters from about 1858 onwards were sewn on machines, the first good sewing machine was about 1853 Quote Al speling misteaks aer all mi own werk..
Members plinkercases Posted June 27, 2018 Members Report Posted June 27, 2018 Here is a good reference site on vintage holster making etc. https://www.vintagegunleather.com/ Quote "Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691 plinkercases.ca
