Moderator Wizcrafts Posted October 16, 2018 Moderator Report Posted October 16, 2018 6 hours ago, JJN said: I looked at the specs and they list maximum thread as 277 but the needle range is 20-24. I think a 277 thread needs a 25-28 needle, doesn't it? I use a #25 needle when I sew with #277 thread. A #24 needle pokes a hole that's too tight, unless the bottom thread is smaller. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members MG513 Posted October 18, 2018 Members Report Posted October 18, 2018 On 10/15/2018 at 1:49 PM, JJN said: Interesting. They call this a Cowbow CB6500 medium to heavy sewing machine. It looks exactly like a Juki LS-1341. That binder is not synchronized, just bolted to a metal plate. I looked at the specs and they list maximum thread as 277 but the needle range is 20-24. I think a 277 thread needs a 25-28 needle, doesn't it? I don't have any personal experience in this range of thread. It must be fairly new as Cowboysew posted the video 3 days ago. Maybe one of the Cowboy dealers can comment here. May I ask, what is the advantage of a “synchronized” binder?? I assume there is a difference between that and one isn’t synched? Quote
Members MG513 Posted October 18, 2018 Members Report Posted October 18, 2018 21 minutes ago, MG513 said: May I ask, what is the advantage of a “synchronized” binder?? I assume there is a difference between that and one isn’t synched? NEVERMIND! I looked it up and found the answer... I couldn’t figure out how to delete my previous question though. Quote
Northmount Posted October 18, 2018 Report Posted October 18, 2018 2 hours ago, MG513 said: NEVERMIND! I looked it up and found the answer... I couldn’t figure out how to delete my previous question though. Would be nice to post your findings hear so others can see without having to go research it too. Kind of helps fill out this thread. Tom Quote
Members CitizenGreyArms Posted March 26, 2023 Members Report Posted March 26, 2023 I wanted to respond to this thread because while looking for a binder for my juki 1341 this thread came up. Aparently the actual juki brand binder kit is no longer made. I found "KHSew" moving arm on ebay, and after ordering found i needed more parts. Youd need the "kh869" arm which comes with a post for the 1341(the arm is for an adler 869 OR juki 1341), as well as the 1341 specific needle plate, feed dog (the moving arm has a pin that inserts into this feed dog which is what makes the arm synchronize to the foot), and their binding foot (i had a random ebay binding foot that happens to work and was 20$). I purchased all the pieces on ebay from a couple different sellers. Juki 1341 Binder They also make a fixed bracket that swings away but isnt syncronized Fixed plate Quote
