Members Silverd Posted July 21, 2018 Author Members Report Posted July 21, 2018 Many thanks. I'll follow up with these folks and see where it goes. I agree that you get what you pay for most the time...and sometimes you dont. Silverd Quote
Members Silverd Posted July 26, 2018 Author Members Report Posted July 26, 2018 I finally heard back from Dan, the Sales manager at Campbell Randall in Conroe, TX. They are setting up an improved rebuilding manufacturing process and are looking at 4-6mo delivery of the Campbell lock stich machine until up to speed. These machines are rebuilt to like new condition using the casting cores from old worn out machines then fit with remanufactured parts...and as such are expensive. Very expensive but as close to a new machine as one can get! IT sounds like their previous manufacturing method used a one at a time Hot Rod approach...The new plan may be more batch type and likely will produce more consistent parts. Dan was extremely knowledgeable about the product and the rebuilding process and he took his time explaining and answering all of my questions. One of the accessories I'm interested in is the Round maker attachment as example. It has a blade on the throat plate and one on the presser foot that cut sew channels into the strap as it is being stitched. When I asked Dan if the attachment really works, he told me the new attachments use the original design and the original hand drawings that were generated in the late 1800's. Nice! A proven vintage design for traditional Bridle work available in todays age. Effectively these machines are functional antiques that have not been redesigned or replaced with a modern equivalent. Only in the Leather industry! There are some interesting characteristics of the Campbell lock stich I'll need to gain understanding of before I buy however. Wiscrafts expounds on the technique of backstitching above; Wow! Very complicated so it seems but possible? I'm wondering how well it will sew cheek buckle pieces considering how big the presser foot is for example? Anybody have experience with this? Silverd Quote
Moderator Wizcrafts Posted July 27, 2018 Moderator Report Posted July 27, 2018 Backstitching with a barbed needle involves rotating the work 180 degrees and carefully lining the needle up on the side of a previous lockstitch. It can be inside the same hole, but must not lay directly on the knot or the existing stitches. Sometimes, rotating the needle a bit makes it easier to lay stitches next to each other, in the same holes. Pick a direction and stay with that alignment. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Silverd Posted August 9, 2018 Author Members Report Posted August 9, 2018 On 7/26/2018 at 10:54 PM, Wizcrafts said: Backstitching with a barbed needle involves rotating the work 180 degrees and carefully lining the needle up on the side of a previous lockstitch. It can be inside the same hole, but must not lay directly on the knot or the existing stitches. Sometimes, rotating the needle a bit makes it easier to lay stitches next to each other, in the same holes. Pick a direction and stay with that alignment. Or one can finish by hand? Silverd On 7/19/2018 at 9:23 PM, Wizcrafts said: You can buy then rebuilt and is perfect condition directly from the Campbell-Randall Company, in Texas. Finally got a response back from the Campbell folks. They have or will rebuild to order a Campbell machine complete with table and 1hp servo drive system for $6250 or head only $5475. Funny thing. They apparently use Haas cnc mills and lathes to manufacture many of the replacement parts used in their rebuild process. I've worked at Haas for over twenty years as a mechanical engineer. If I can get them to provide me with a shipping quote we may do some buisness. However I'm not getting a warm and fuzzy feeling about their customer service at this point. I like the idea of buying a tight machine that is well supported but my experience so far in this industry has been minus the well suppored part. Just saying. I think that may be one reason why a forum like leatherworker.net gets the traffic it does. The folks here have been way more informative and supportive than the equipment supplies I've dealt with. It's been an eye opening experience let's just say! Silverd Quote
DonInReno Posted August 10, 2018 Report Posted August 10, 2018 (edited) oops - my mistake it was a union lockstitch on cl. Edited August 10, 2018 by DonInReno Quote
