Members brmax Posted July 25, 2018 Members Report Posted July 25, 2018 Good morning! I have an interest in a source for a ( listen ), larger servo pulley. Can you imagine that. Well I am and particularly with a bore diameter of: 12mm The shaft is looking to be 11.8 - 9, so my interest is possibly up around 120 + or - As Im working with a compound system at the present and just experimenting. Oh and about forgot the typical 3/8”or M, 3L v-belt size In my homework, I havent called the Pro dealers at this time. Thanks everyone Floyd Quote
DonInReno Posted July 26, 2018 Report Posted July 26, 2018 If you’re just experimenting I’d grab a 1/2” bore adjustable pulley - shim the difference with a thin wall tubing that fills the space close enough. Although I was never intrigued by adjustable pulleys, I picked up a handful on a $2 clearance sale and like them more and more. Quote
Members brmax Posted July 26, 2018 Author Members Report Posted July 26, 2018 Thanks Don for the tips. Running onto a sale with them pulleys you found is for sure a prize. With some patience Im waiting on a 3/8” bore pulley and with some plans to drill it with a 15/32 bit. Im sure a bit of sand paper in the bore to finish. Hey appreciate it Floyd Quote
Members plinkercases Posted July 26, 2018 Members Report Posted July 26, 2018 I have had the same challenge with machine pulley where the shaft is 12.76mm..... no luck finding stock parts but am still trying to make 5/8 ID with a sleeve work... sleeve is the tricky bit now. And it seem seems the motor shaft is the same diameter...old Consew motor but I found a small diameter pulley that they say will work... just received it and haven't tried yet. Quote "Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691 plinkercases.ca
Members Constabulary Posted July 26, 2018 Members Report Posted July 26, 2018 (edited) if the pulley has a 15mm bore roll up a 1.5mm copper sheet strips to fill the gap or use a aluminum tube 12x1.5 Check the pictures in this post: http://leatherworker.net/forum/topic/62817-do-i-have-a-complete-busm-pearson-6-or-what/?page=2&tab=comments#comment-436138 Edited July 26, 2018 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members brmax Posted July 26, 2018 Author Members Report Posted July 26, 2018 Strange as it sounds, I glanced up and noticed a couple thread stands the same. Top section o.d. = .625”/15.8mm and the i.d. = .5”/12.8mm Its been my experience, if it takes all day to find an item like this today. Sure enough tomorrow the same item will be discovered in a crazily simple manner. Silly but typical, I thought prior to this project i would be set on using a couple old 15mm pulleys, to my suprise the SW6000 has the shaft end turned down to a smaller diameter versus the the old 5000’s Great tip and link there, with the shim materials being pretty accessible. Good day Floyd Quote
Members gr8legs Posted July 27, 2018 Members Report Posted July 27, 2018 On 7/26/2018 at 7:42 PM, plinkercases said: I have had the same challenge with machine pulley where the shaft is 12.76mm..... no luck finding stock parts but am still trying to make 5/8 ID with a sleeve work... sleeve is the tricky bit now. And it seem seems the motor shaft is the same diameter...old Consew motor but I found a small diameter pulley that they say will work... just received it and haven't tried yet. Expand That 12.76 mm sounds a lot like 1/2" plus a smidgen of schmutz on the calipers. . . . but if it's correct you might have an easier time getting an adjustable reamer to enlarge the hole in a 1/2" bore pulley instead of sleeving down a larger pulley . . . Of course it is entirely possible that I don't understand the problem. Stu Quote
