maybe a misprint - don´t know.
Or look at the foot lift levers of your 111´s - not sure if there were different types for different foot lift heights (different part numbers?) if not and all 111 are using the same lever you should be able to tweak it a bit because I doubt they used a lot of different parts in the different subclasses - compare the parts lists. Will check my parts bin if I can find different levers - I know I have 1 or 2 spares...
EDIT:
yes - different levers - but I don´t know if the black one probably is a DURKOPP (they share parts with Singer). Do you see the difference?
Edited by Constabulary
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Yep, quite noticeable. I assumed, however, that they were referring to working distance under the feet, not "lifted" distance?
