Members Zesan Posted October 1, 2018 Members Report Posted October 1, 2018 I have just acquired a juki dcs 246, I got a manual online. The manual says to set the needle height by the mark on the needle shaft. When I do this it is not even close to the hook. Anybody else have a machine like this? Any other reference for setting the hook timing? Quote
Uwe Posted October 1, 2018 Report Posted October 1, 2018 A link to the manual you're using would be helpful. It's not clear what the manual actually says and what you actually did. 39 minutes ago, Zesan said: set the needle height by the mark on the needle shaft. When I do this it is not even close to the hook You'll have to elaborate on that and be more precise in your description. We can't see your machine. Quote Uwe (pronounced "OOH-vuh" ) Links: Videos
Members dikman Posted October 1, 2018 Members Report Posted October 1, 2018 Is the right length needle fitted? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Zesan Posted October 1, 2018 Author Members Report Posted October 1, 2018 It does have the right needle. I did find the reference Mark's while trying to take a picture, let me see if I can get it with that. Thanks for the response. Quote
Members Zesan Posted October 1, 2018 Author Members Report Posted October 1, 2018 (edited) I am struggling with this new iPad to copy and paste the link Edited October 1, 2018 by Zesan Too big Quote
Members Zesan Posted October 1, 2018 Author Members Report Posted October 1, 2018 Quote Now that I found the marks, I am not clear where the wheel should be in relation to this. I can put the mark there every time with the wheel but that seems like it would not be adjusted. I took the hook assembly off to clean. So I am resetting everything. In the first picture where should the wheel be as far as say the thread take up lever or is there another reference point to for the “bottom of the cycle” Quote
Members R8R Posted October 1, 2018 Members Report Posted October 1, 2018 I think to set the needle height the hook at least needs to be at least roughly timed? If the hook is advanced or retarded far away from the needle when it's 2.4 mm up from bottom trying to set the final height is kinda pointless. Quote
Members R8R Posted October 1, 2018 Members Report Posted October 1, 2018 Just for reference, is this the manual you are looking at? http://www.juki.co.jp/industrial_j/download_j/manual_j/dsc240/menu/dsc246,-7/pdf/instruction_eg.pdf Quote
