Does anyone have adjustment procedure for reverse stitch length for a Consew 206RB-4.  I have looked everywhere on the internet and the only information I have found is for the 206RB-5 and the newer model has different parts than the 206RB-4.  I called Consew tech support and they were clueless on how to adjust the older model.
Went to to a local sewing machine shop and they said they could order me a tech manual for $40, but I hate to spend $40 for one adjustment procedure.
I hope that someone out there has done this adjustment on the -4 modeland can provide some direction!
Thanks!
Gary
Cowboy 4500, Consew 206RB-4
Thats a lot cheaper than calling in a engineer and you will probably save a lot more using the manual for other adjustments
Maybe you have a bit of Scotland in your blood, tight sods up there
Mi omputer is ot ood at speeling , it's not me
LOL!  I’m Polish - we are just as tight with a dollar as the Scots!
You are right about the manual, but I have gone over the entire machine and have it running great, except for the reverse stitch length.  If I cannot find the adjustment procedure I guess I will have to break down and order the manual.  My concern is that they will order a manual and what will come in is a manual for the newer 206RB-5, which will not help me.
Gary
Here is an instruction manual specifically for the 206rb-4 in pdf format at ebay for $4. I am not sure if the information you need is in the instruction manual.
https://www.ebay.com/itm/Consew-206RB-4-Instruction-Book-Operating-Instructions-Manual-PDF-File-Document/183457297738?hash=item2ab6e8354a:g:Ye0AAOSwpP9Y4~8D
Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S,  Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
Thanks for the link!  I think I saw this manual somewhere on the internet and think my machine did not look the same inside, but I am probably mistaken.  I guess for $4 I have nothing to lose!
Gary
