Ragingstallion Report post Posted October 19, 2018 so, I have made 2 mouse pads before, but have never put anything under them to give them a better grip. the one I am using at work likes to slide around now after so much use. use to be decent at staying in place, but now I think its time to upgrade it. any ideas on what I can add to the bottom that is not to bulky or wont leave a residue? Quote Share this post Link to post Share on other sites
Ferg Report post Posted October 19, 2018 I buy closed cell rubber sheet 1/16" thick, it is black/charcoal in color. I use spray can glue. On both the foam and the leather. Cut the foam so it is about 1/8" shy of the mouse pad all the way around. I apply the foam to the leather immediately after spraying so if I need to adjust it I can move it slightly. Allow to dry over night. Works great. Ferg Quote Share this post Link to post Share on other sites
ScoobyNewbie Report post Posted October 19, 2018 Is that the same as the stuff you put under rugs that you don’t want sliding around? At menards, Lowe’s and of course Wally World. Quote Share this post Link to post Share on other sites
Ferg Report post Posted October 20, 2018 Definitely not. I will try to locate my order when I bought the material. Will post when I find it. Ferg Quote Share this post Link to post Share on other sites
Ferg Report post Posted October 20, 2018 I ordered product from RUBBER SHEET WAREHOUSE. In Alhambra, CA 91803 Item# NSAPRAB-1-16IN-062-7. 1/16" Neoprene Sheet All purpose rubber. Believe I found it in smaller pieces from other sources. Ferg Quote Share this post Link to post Share on other sites
ScoobyNewbie Report post Posted October 20, 2018 Cool, thanks. Quote Share this post Link to post Share on other sites
