Does anybody know where I can find baseball cores?  I can't find anything on the web.  I could always just buy cheap baseballs and re-cover them, but I figured cores would be cheaper.
Thanks,
JC
I don't know where to get your baseball cores from, but I am wondering if buying cheap baseballs is false economy. Are the cores similar in cheap baseballs and more expensive baseballs?
Kindest regards
Brian
"Whether you think you can or whether you think you can't, you are right"  Henry Ford
Machines: Singer 201p, Kennedy,  Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
They are not, but as long as they are regulation size the template will work.  I am re-covering them with words, names, tooling, dyeing, etc. to be a keepsake or trophy, not for real use.  So the core materials are a little irrelevant.
Maybe just make a rubber band ball of the correct size? If they aren’t going to be smacked around maybe that would work? You can get those at Office Depot...
