KennethM
Ammo butt stock
Hello everyone.Hope everyone is having a great new years.My nephew got his first riffle for Christmas.A Remington 770 308.I want to make him a Ammon butt stock carrier.
I think I have a idea on how to do it but could use some advice.Here is what I was going to do.
Use 6 oz veg tan ,that's the total is..2 ,3 oz panels.
Trace the stock on some paper for my pattern.Tool the top layer.Add my eyelets.Then glue that layer on to another layer so the eyelets wont scratch the stock.
I was going to cut a strap and some slots out .Then weave the strap in and out the slots for the Ammon belt.
Some questions..
How do I figure out how far apart to add the slots for the ammo.
Do you guys add extra room on the pattern for the leather thickness?
this may help...worked great for loops on a belt billet..
Some questions..
Just wanted to see if you had any luck.
Some questions..
Hey, Ken, . . . couple notes, . . .
6 oz will be good for the outside panel, I use 6/7 for my gun belts and it works out fine.
3/4 oz calf is the "top of the line" for the loops, . . . but can be hard to come by.  I use 4/5 veggie tan, . . . punch the holes at 3/4 inch long, . . . cut the strap just over 13/16, . . . makes a nice fit.  Wet the strap good before you start the weave, . . . pull it thru, . . . then back thru the same slot, . . . pulling it tight around a cartridge, . . . and leave the cartridge in there for a good 15 to 20 minutes, . . . then very gingerly slip the cartridge out and let it all dry.
I would not use 6/7 for a backing, . . . probably 3/4 or pigskin, . . . 6/7 will make it almost 1/4 inch thick . . . kind of hard to handle.
Measure the diameter of the cartridge, . . . the thickness of the leather, . . . add 1/16 of an inch, . . . that is the dimension, center to center, that you want to punch your weaving holes.
May God bless,
Dwight
