Ok so I've made several belts but only a few with names on the backs (centered). I made one for a Christmas gift this year and the name wasn't centered. The customer messed up a measurement but not by enough to throw the name off that much. So how do you do it? Center the name based on the measurement from the fold to the hole they use or based on the measurement from the buckle to the hole they use? Maybe I'm putting too much thought into this but I'm remaking the belt and don't want to mess up again.
CENTER of the buckle, . . . tothe the hole most used, . . . divide that dimension in half, . . . that is your center point for the name.
May God bless,
Dwight
Edited by Dwight
www.dwightsgunleather.com
If you have the belt that was wrong you should be able to just measure over however much you were off and re do it.  Then use that belt as a guide to let you know how to measure for your style of work.
Todd
