Members JosePirul Posted January 16, 2019 Members Report Posted January 16, 2019 Hello everyone, I found this forum a while ago but this will be my first post. I only had my Cobra class 26 for about 2 weeks but I love how this machine functions, I'm learning every day more things about it. My problem (well other then learning how to stitch better with it) is that the presser foot marks the material, on chrome tan is not that noticeable but on some of the vegetable tan sometimes it marks it pretty bad, is there something I can do to not marker it that bad, or maybe a new foot I can buy for this purpose? Thanks everyone. P.S. I tried to search for this on the forum but I couldn't really find anything. Quote
Moderator Wizcrafts Posted January 16, 2019 Moderator Report Posted January 16, 2019 What type of feet came with your Cobra 26? Post a picture of them. If your machine uses standard Singer 111 style feet, buy a wide outside foot, or a complete extra wide inside and outside set. The wider the footprint, the less it digs into the leather. There are dozens of different presser feet for standard walking foot machines based upon the Singer 111w155. Second, try backing off the top pressure screw. It only needs enough spring pressure to hold down the leather until the needle has cleared it on the way up. Less foot pressure results in less marking. If none of the above work, try taping a thin piece of hard leather next to the left side of the stitch line. This will act as a buffer between the outer foot and top grain and won't interfere with your edge guide on the right. If you are using a right toe foot, tape the buffer piece on the right side of the stitch line. Leave enough clearance for the inside foot to make full contact with the top grain. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members JosePirul Posted January 16, 2019 Author Members Report Posted January 16, 2019 Thank you Wizcrafts, backing off the pressure screw worked great, very minimal marking now. Quote
Members nautilu007 Posted January 30, 2019 Members Report Posted January 30, 2019 (edited) Hello, i have same problem with my new Cobra 26. Try to adjust pressure screw, but didn´t help a lot. Can I ask you where can i find wide outside foot, or a complete extra wide inside and outside set? Thank you a lot Edited January 30, 2019 by nautilu007 Quote
Moderator Wizcrafts Posted January 30, 2019 Moderator Report Posted January 30, 2019 3 hours ago, nautilu007 said: Hello, i have same problem with my new Cobra 26. Try to adjust pressure screw, but didn´t help a lot. Can I ask you where can i find wide outside foot, or a complete extra wide inside and outside set? Thank you a lot If the model 26 is a triple feed walking foot machine, it probably uses standard type 111 inside and outside feet. They are sold by all industrial sewing machine dealers who aren't exclusively Adler or Pfaff associates. Ebay sellers have all manner of walking foot sets. Then again, try the place where you bought your machine! Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
