Moderator Wizcrafts Posted January 26, 2019 Moderator Report Posted January 26, 2019 7 hours ago, Constabulary said: I haven´t darned anything yet I´m using ZZ for repairs. However, I think I will try my 34K for darning. I think for darning you need the momentum in that the presser foot is holding down the material or you have to put the material in a embroidery / darning frame (or what ever it is called). BTW - there was a darning attachment for Singer 29K and Adler 30 patcher machines - not sure if there ever has been one for CLAES patchers. AFAIK WIZ has one Yes, I have darning attachments on my Singer 29k71 and Adler 30-7. I use them once in a while to get longer stitches, or to darn across tears in material. These attachments have three positions: off, medium lift and high lift. You just rotate the T shaped handle so it either hits or misses the rising needle bar. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Evo160K Posted January 26, 2019 Author Report Posted January 26, 2019 6 hours ago, Wizcrafts said: Yes, I have darning attachments on my Singer 29k71 and Adler 30-7. I Wiz, are you able to post a pic or two of your darning attachments? Thank you Quote
Moderator Wizcrafts Posted January 27, 2019 Moderator Report Posted January 27, 2019 Here ya go! Darning attachment. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted January 27, 2019 Members Report Posted January 27, 2019 I think we already talked about it a while ago but forgot about it. So the device replaces the hex screw, right? Internally I guess the "T handle" thing is spring loaded so that is stays in place while darning , right? Or does it "click" into a certain position? Can´t be too difficult to make if the Hex screw has a standard threading... will check that... Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Moderator Wizcrafts Posted January 28, 2019 Moderator Report Posted January 28, 2019 19 hours ago, Constabulary said: I think we already talked about it a while ago but forgot about it. So the device replaces the hex screw, right? Internally I guess the "T handle" thing is spring loaded so that is stays in place while darning , right? Or does it "click" into a certain position? Can´t be too difficult to make if the Hex screw has a standard threading... will check that... It is spring loaded and free turning. You just turn it to the desired position before it is hit by the needle bar. It can be mastered in about 5 standard Earth minutes. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members MariaMS Posted March 2, 2024 Members Report Posted March 2, 2024 Interesting topic..... I have what I think is a Singer model 47 coming. Don't know the subclass as it went straight to storage and I can't see it in the pics. It currently has a roller foot, but I want to look into if I could get it darning. Was wondering if anyone has modified a domestic darning foot...... there are a few different ones that might work perhaps...... Quote
