Members Sugarkryptonite Posted January 29, 2019 Members Report Posted January 29, 2019 (edited) Hi guys I recently installed my servo motor on my machine, having trouble measuring the belt for it. I used a string, got it decently tight wrapped around both pulleys in their loosest position (as in no tension would be on the belt), measured the string on the ground and got 39 inches. Later that day I went to buy a 39 inch belt, got home and it's not even close! A few inches short at least. It clearly says on it 39, and I measured with the string multiple times to be sure. Now after that, I used a couple calculators online for v belt length where you put in both pulley diameters and the center to center spacing between the two, and I get roughly 41 inches, which sounds like it could work, but why such a big difference with the string? When I measured the pulley diameters I used the outside diameter, not the inner sheave portion, it is unclear on all these sites where you must measure exactly. Any thoughts? Edited January 29, 2019 by Sugarkryptonite Quote Singer 111W153 walking foot & Siruba W122-356 coverstitch
Members brmax Posted January 29, 2019 Members Report Posted January 29, 2019 I also found measuring the out side of the pulleys are the best and closest. So I think your on the right track! Although this is if were using a 3L or similar 3/8” width pulleys and belt. I found measuring the outside of the belt is my best bet. Good day Floyd Quote
Members Constabulary Posted January 29, 2019 Members Report Posted January 29, 2019 On my side of the pond you find 3 different measures for V-belts - abbreviation are: LI, LW and LA LI = length inner side of the belt (German: Länge innnen) LW= datum length of the belt (not sure if this is the correct translation) (German: Wirklänge) LA= length outer side of the belt (A = außen = outer suide) (German: Länge außen) So there can be a difference, but not sure how the official measuring on your side of the pond is. Just wanted to give this as a hint. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members trash treasure Posted January 29, 2019 Members Report Posted January 29, 2019 (edited) I use a tailor's cloth tape measure, and measure around the outside of the pulleys - Usually get it pretty close. If you buy from a place like McMaster Carr, they list belts by the outer circumference, so that measuring method works well : https://www.mcmaster.com/drive-belts Also, there are on-line belt calculators : http://www.calculatoredge.com/mech/vbelt length.htm Edited January 29, 2019 by trash treasure more info Quote The model number giveth, and the subclass taketh away ......... Sometimes
lambchop Posted January 29, 2019 Report Posted January 29, 2019 (edited) Lenght of Belt = Distance between pully centers X2 + 1/2 Circumference of top pully + 1/2 Cirumference of bottom = Lenght of Belt if using correct belt width for pulleys Edited January 29, 2019 by lambchop Quote
Members Sugarkryptonite Posted January 29, 2019 Author Members Report Posted January 29, 2019 Thanks all, I got a 42" and it fits like a glove. Note for newbies, do NOT measure inside the sheaves like I did with your string if you do it that method. I suggest the calculators shown here and online for calculating V belt lengths (as well as lambchop's formula, calc is just easier). Quote Singer 111W153 walking foot & Siruba W122-356 coverstitch
