Members Cheval Posted February 9, 2019 Members Report Posted February 9, 2019 I have one of these machines on order, my first two needle machine- Is there a consensus out there that using a right twist thread on the left needle yields a better result than using left twist on both? In the manual is states you can use left twist on both needles without issue. I’ll be using Tex 70 to 95 most of the time. Curious what others out there are doing. C Quote
Members shoepatcher Posted February 10, 2019 Members Report Posted February 10, 2019 Use the right twist on the left needle. It will work better./ glenn Quote
Members Gregg From Keystone Sewing Posted February 11, 2019 Members Report Posted February 11, 2019 See attached, this will help people understand a bit more where Left or Z twist or Right, or S twist is commonly used. Usually, if the thread is bonded well, this is not critical, but if you are trying to max out the performance, this is one more thing we can look at. The_special_application_needle_SAN_12.pdf Quote
Members Cheval Posted February 11, 2019 Author Members Report Posted February 11, 2019 (edited) That's interesting, I had come across that document prior in my searching- it gives the impression that the SAN 12 needles will correct the twist issues on their own without adding in an S twist thread. I'll have to check those out when testing. Thanks! C Edited February 11, 2019 by Cheval Quote
Members gottaknow Posted February 14, 2019 Members Report Posted February 14, 2019 If the hooks are sharp and set correctly, no need for right twist thread on the left needle. Regards, Eric Quote
