Hi wlg1908, I would suggest that you check with your local hardware / flooring store, somewhere they sell laminate flooring. The only difference I see between the one you listed and the one I sometimes use is the adhesive backing. Having the adhesive ability maybe a benefit to have for what you are doing. Checkout the flooring store and see if they have a scrap to try.
The one I use is called Black Knight ( https://melmart.com/brands/black-night/ ) made as 1/8" underlay for laminate flooring which is also closed celled with a vapour barrier adhered to it that easily peels off. I use this as a anti skid pad on the bottom of dog beds and knee rests type stuff as it also doesn't shrink. Hell haven't even had any problems with machine washing / drying it. Sewing it can be a bit awkward at times as the material is semi flexible but can be a bit sticky on the needle / thread.
kgg
I get my neoprene from Foamforyou.com
You can get it with or without adhesive.
