Hi! So im very new to both leatherwork and this forum. I'm having a bit of trouble with finishing a project. This is my first real thing I've made, so any tweaks I could do or hints would be very much appreciated.
I need to finish the sides of it but don't know how I would do it. I've used 3.6mm thick leather for the whole thing and it will be used to strap onto a belt for work. I have got a 2mm leather that I want to use. Any ideas?
Thanks!
Considering that you seem to have stained, burnished edges, and finished what you have, . . .
I'd probably hole punch the ends, . . . and so a "X" lacing, . . . like shoe strings, . . . but loose, . . . it would hold the sides together and make a "pouch" out of it for your phone.
First thought anyway, . . .
Or if you are truly ambitious, . . . you could sew a toe plug into each end (search toe plug on here, . . . you'll see what it is).
May God bless,
Dwight
May God bless,
Dwight
Thanks very much for your reply. What thickness of leather would be best for the toe plug?
I would use the same leather to match the colour, but I would skive the edges to assist with bending, fitting and stitching the plug.
I think you probably used 9 oz for the project, . . . and a toe plug that thick for that type of project would be overkill.  I would probably use 4 to 5 oz, . . . or about 1.5 mm to 2 mm.
That will make it not so rigid, . . .
Just the way I would do it.
May God bless,
Dwight
Probably make it easier to stitch and be easily sufficient for the job as well, but I would use the same leather so the colour and texture of the leather is exactly the same. I am not known for taking the easy road.
Thank you for all of your answers! Unfortunately I cannot get the same leather but thinner, I have purchased a thinner 2mm leather that is darker that fits quite well, and I will attempt a toe plug. Thank you for your advice! I will post a pic of the finished product (if it goes well)      :)
