I am new to this and I need a draw down stand to start my first saddle. Does anyone have one for sale? If not, can you tell me where to get the part where the arm hooks in to hold it down? I havent seen anything like it at the hardware store.
Get yourself a piece of 1/8 or 3/16 flat iron the size you need and using a side grinder and saftey goggles you can make the piece. the catch to fit into these can be shaped on an anvil real easy. Greg
Gay,
The metal combs like Greg is describing are pretty easy to adjust, you can just step on the bar and kick it over into wherever you want. Most any welding shop should be able to make one up for you if you don't have the tools.
I made mine a little different on the wooden stands. I have attached some pics. The bar hinges off the back. I drilled a series of holes in the front. I put a gatepost bolt or piece of rod through the holes over top of the bar, and then stick a wedge in over the bar/under the rod to provide tension. The further you pound it in, the tighter the tension. Not as quick to adjust, but these parts are all available at the hardware store or lumberyard.
Bruce Johnson
Malachi 4:2
Gay,
That one looks like something I can do! Any idea of how tall to make it? I'd hate to build it and find out its too uncomfortable to use!
saddle_horse.JPGI made mine taller than I think most have. I made it high enough so that i can do all work standing upright so that I don't have to bend over and stoop. The highest point is about navel height
"If You're not behind the Troops, please feel free to stand in front of them"
Gay,
The pictured stand is 46" high I think. I originally made one out of a saddle rack that was 39" high. Between the two, I was able to do what I needed without excess bending. It was nice having the height differences. The issue was that I had two drawdowns, they took up twice as much room, I was always moving from one stand to the other to do what I needed more comfortably, and it there was always a saddle on the other stand. This spring I got a hydraulic stand and would not go back. I sold the lower wooden one, and kept the tall one to set stirrup leathers on repair saddles, or other minor things if the hydraulic was being used. It is still out in the shed I stuck it in. Makes a dandy rack for saddle blankets and pads at the moment.
Bruce Johnson
Malachi 4:2
Gay,
I looked at those hydraulic stands online and they look great! I can see how having an adjustable height is advantageous. I just cant justify spending that much money without knowing if I am capable of actually building a saddle. I did find a hydraulic chair base on ebay for 20 bucks. I think I'm going to try and make my own stand with that. Do you use the tilt feature very much? Would you go to the trouble to try to add that or just go with a plain stand?
Gay,
My stand from Ron's Tools has an arm that raises up to tip the tree at different angles. The actual top doesn't swivel like the Weaver model. The Weaver pivots in two directions. The arm is an OK feature, but not an absolute requirement. There is not a wooden stand that raises up and pivots without raising the base. Millions of saddles have been built on them. If I needed to tilt the wooden stand, I put a something under the front or back.
The biggest reason I had two drawdowns of different heights was to make the different things easier. The lower stand was good for shaping ground seats and doing fork covers and cantles. The tall one was good for sewing horns and cantles, installing strings/conchos, stuff I would have been bent over in one postion for a time on the lower one.
One thing I would do if I was making my own. Make a contoured top to set the tree in. A rocking tree is exasperating. The shape will hold better. The Weaver has a flat plank with some kind of rupperized cover. Trees rock, and slip occasionally. One of my friends says always at the worst time.
Bruce Johnson
Malachi 4:2
Gay,
I think I can do the tilting stand thing. I bought the hydraulic stand for 20 bucks, and found a pivoting, tilting table that I can canabalize to get the joints to build the articulating part of the stand. I should adjust up to 20+ inches, rotate, and tilt.
I just got the first saddle tree I want to work on today so I hope they send the parts for the stand quickly! I am starting with a mexican saddle tree. I ordered it from mexico with mule bars. It seems to fit my mule pretty good. I just cant wait to get started! Course its nothing like the video I bought on saddle construction so I am going to be flying blind! Wish me luck and thanks again for all of your advise. I will post pics of the stand when I get it built.
A couple years ago at the IFOLG show in Denver, Charley Crow showed a mexican style saddle that he had made. Here is a picture of it. Charley is a really nice guy and I bet he would be willing to answer any questions you had if he could. I would just have to try and find his email address somewhere. I guess if I do, I should invite him here.
