22 hours ago, chrisash said:
Can you put more pressure on the feet to hold it down a bit more
I have been trying that, but it doesn't always work and ends up messing up the stitching when it doesn't. :/
21 hours ago, Bob Blea said:
How thick is your leather?  Have you sewn this leather before without any problems?
Is there any chance that your timing is off and the shuttle is nicking the needle and either bending it slightly or putting a burr on it?
You could try waxing the needle with beeswax to see if it has an effect.  The wax would wear off quickly but it might tell you if friction is the problem.  For the ultimate in non-stick if you have non-stick cooking spray in the house try spraying some in a cup and then using a q-tip to apply some on the needle.
Leather is two layers, 10-12 oz skirting.  I've never had a problem with the thickness before.  Needles are 25s I believe and can't remember thread off the top of my head, but it was ordered from Leather Machine Co specifically for the Cobra 4 and what I am doing.  I checked both needles and neither have burrs.  I've also sewn through test pieces with no issues, the cement seems to be the catalyst.  I have the pieces sitting out in the sun to see if lack of cure was the issue.
16 hours ago, Northmount said:
@ValkyrieEquine Moved your post to leather sewing machines.  You'll get more participation from this group.
Tom
Thank you!
4 hours ago, chrisash said:
Sorry i don't see where i am wrong, surly the only job of the pressure foot is to hold the leather down tight until the needle tip has passed the leather clear on the up stroke so the leather can be moved for the next stitch, if the needle sticks and raises the leather with the needle, then the problem lies with the pressure being to week
Not sure if someone else said you were wrong, but I didn't.  I'll look into seeing if that is something that will help.
1 hour ago, Sonydaze said:
Sometimes I sew two layers of glued together 16 oz. sole bend. Is it is very dry and hard, the needle tends to stick. (good needle, right needle thread combination & max pressure foot tension.)  My experience is that rubbing beeswax on the needle helps. It doesn't last for long but it seems that after awhile the needle polishes to become slicker and then you don't need the wax as often.
Thank you, I will try that.  Where do you get your beeswax?
Running thread thru a thread lubricator with silicon lube should cure the problem.
glenn
Are the Ti-nitride coated needles slicker than standard needles ?
 always used silicon on the heavy thread cord and works great  . But I ( have not ) tried the Ti coated needles yet and wondering if anyone uses ?
I use titanium coated needles in all of the machines that accept systems DBx1/16x257 and 135x16. They cost about $2 more per pack of 10 and are less likely to stick in the material from heat or basting tape.
Posted IMHO, by Wiz
