Members dikman Posted April 19, 2019 Author Members Report Posted April 19, 2019 It has now been 16 days since I clamped the rawhide discs, and it looks and feels dry. I cast a brass disc and turned it down to fit on the end, threaded it and Loctite'd it to the end of the rod. To do this I had to remove the clamping piece and when I did it was obvious that it still hadn't dried in the centre!! I still had a tight mass, however, so I screwed it down the rod so it applied pressure to the brass while the Loctite dried. I removed the other clamping piece and I guess I'll just have to leave it open to dry off more. (Note to self, I think I'll stick to making them out of plastic milk jugs!!!!). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members YinTx Posted April 20, 2019 Members Report Posted April 20, 2019 Coming along quite well. I have an old mallet that needs new rawhide discs, so I've been following along on this to see if I can glean some insight on how to accomplish it. Thanks for sharing so far! YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
Members dikman Posted April 20, 2019 Author Members Report Posted April 20, 2019 No worries, Yin. The dark centre of the mass doesn't feel damp, but it's obvious that it can't be completely dry yet. It has formed a pretty solid lump, though, as it can be screwed along the rod without any of the discs coming loose. I'm going away for a couple of weeks so I'll let it stand, open at both ends. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members dikman Posted April 23, 2019 Author Members Report Posted April 23, 2019 I've been examining the maul and I don't think it's damp as it's quite hard if I poke it with a screwdriver. I know you can make glue from the rawhide, so I'm guessing that the moisture combined with the pressure from clamping it formed some sort of natural "resin" (for want of a better word). I'm going to be away for a while (holiday by the sea) but when I get back I think this will deserve a stacked leather handle. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
CFM chuck123wapati Posted May 29, 2021 CFM Report Posted May 29, 2021 On 4/23/2019 at 4:33 AM, dikman said: I've been examining the maul and I don't think it's damp as it's quite hard if I poke it with a screwdriver. I know you can make glue from the rawhide, so I'm guessing that the moisture combined with the pressure from clamping it formed some sort of natural "resin" (for want of a better word). I'm going to be away for a while (holiday by the sea) but when I get back I think this will deserve a stacked leather handle. So did you finish this maul? If so how is it holding up? I am thinking about making one. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members dikman Posted May 29, 2021 Author Members Report Posted May 29, 2021 (edited) Yep, all finished and it seems fine. I don't know why I didn't finish off this thread (sorry about that, chief). I'll take a photo later of the final product. Reading back on this it was a lot of bloody work!!! Edit:I just found a photo of the finished maul, I must have forgotten to post it. I made the handle out of wood segments because it was easier than using stacked leather. Edited May 29, 2021 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
CFM chuck123wapati Posted May 30, 2021 CFM Report Posted May 30, 2021 13 hours ago, dikman said: Yep, all finished and it seems fine. I don't know why I didn't finish off this thread (sorry about that, chief). I'll take a photo later of the final product. Reading back on this it was a lot of bloody work!!! Edit:I just found a photo of the finished maul, I must have forgotten to post it. I made the handle out of wood segments because it was easier than using stacked leather. Awesome indeed i think cutting out all those washers is going to be a pain but i guess not as bad as fleshing out and scraping the hide was lol. i have a hole saw that should work nicely it uses a drill bit in the center so two jobs at once Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
