Members blackmad Posted April 18, 2019 Members Report Posted April 18, 2019 It seems like both machines say LU-563 on them, and the main difference is the stitch length + lack of reverse. I just bought a used 563 and am missing reverse more than I expected. I'm wondering if it's possible this is a 563 that just doesn't have the lever, or if it's a 563-3. Quote
Members Pintodeluxe Posted April 18, 2019 Members Report Posted April 18, 2019 (edited) That's a good question. Can you add a picture of the right side of the head? I'd like to see if there's a bracket for the reverse lever there. It's usually black, and functions as a limit for the reverse lever travel. Here is a related post you might find useful. Edited April 18, 2019 by Pintodeluxe Quote
Uwe Posted April 19, 2019 Report Posted April 19, 2019 (edited) The Juki LU-563 Subclass 3 machines normally have a separate little sticker just below the main ID plate. That little “Subclass 3” sticker can easily come off and get lost. In my book any Juki LU-563 without reverse is a Subclass 3. The standard Juki LU-563 also have a tell-tale reverse lever shaft attachment point visible on the left side of the riser. That detail is missing on your machine. So yours is a Subclass 3, as opposed to a regular LU-563 which just had the reverse lever removed. Edited April 19, 2019 by Uwe Quote
Members Gregg From Keystone Sewing Posted April 19, 2019 Members Report Posted April 19, 2019 562 is a regular G bobbin, 563 is large U bobbin, and 563 Subclass 3 is NO reverse with heavy hook, same that comes with the new LU-1508NH model. See attached brochure. LU-562-3ProductBrochureKeystone.pdf Quote
DonInReno Posted April 20, 2019 Report Posted April 20, 2019 The class 3 would still be awesome if it had the correct holes in the casting for the necessary parts to make reverse work, but it doesn’t. Quote
