Here is a deer skull wallet I recently finished. It matched the change purse I made earlier. Outer shell is 4-5oz veg-tan and the inner parts are 2-3 oz veg-tan.  Dye is Tandy Eco-Flo medium brown applied with an air brush. Hand stitched with Tandy waxed nylon thread.
Nice job!  Stitching is nice and even from the edges.  Did you trim the edges after you stitched?
Gary
Cowboy 4500, Consew 206RB-4
Gary
Thanks, I did not trim after stitching but I made sure the edges were even and square before I marked out the stitches and tried to make sure my stitching chisels did not wander. Due to the total thickness of approx 1/4" I punched the outer shell first, then glued together and and punched the inner layers using the outer shell as a guide.
Congratulations - you did a good job!
