So, am I correct in assuming your belt blanks are cut over width, ends and holes punched then the belt is cut to width?
Kindest regards
Brian
"Whether you think you can or whether you think you can't, you are right"  Henry Ford
Machines: Singer 201p, Kennedy,  Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
I feel like an antique doing it all the 'old fashioned way'   :)
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
Yeah! A strap cutter, a knife and a straight edge ... who woulda thought ... :rolleyes2:
Kindest regards
Brian
Depends on if the are combination style belts. If it just one leather I cut it to size and they get the above treatment. If they are a combination, the strips get cut oversize then attached together then second cut through a combining machine that cuts about a 1 1/2mm off each side and then it gets the buckle and tongue holes put in as above. Here is a couple of pictures of my combining machine doing what it does -
You could do this on a belt strap cutting machine with a few mods as well if you were so inclined.:dunno:
I will be showing some more on this in an upcoming post on belt making in the next couple of weeks.
Yep I still go that way on the odd one off.
YouTube Channel
Instagram
