Members beltbuckles Posted June 18, 2019 Members Report Posted June 18, 2019 so which order do you guys do the gusset for a bag or briefcase as far as gluing and stretching the leather... if i was to make a briefcase or bag that has a "U" shape gusset on both sides... do you guys just keep the leather dry and try to stretch it, and glue it? do you case the leather and then glue it? do you put the contact cement on first and then get the leather wet? if there is a link or people have experience doing it well and consistantly, please help. Thanks Quote
Members beltbuckles Posted June 18, 2019 Author Members Report Posted June 18, 2019 as a side note,, this is after i dye the piece so i don't want to get the leather too wet to discolor the leather Quote
RockyAussie Posted June 18, 2019 Report Posted June 18, 2019 @beltbuckles I think a picture of the type of construction would help a lot. Are you wanting to take the gusset all the way around in one piece with the edges facing out to be later burnished or edged? Although I have done it this way at times it is a lot easier and without a lot of skiving and twisting if done in the 3 piece method as used in these bags below. These following pictures a just some from a prototype one I was working on which later turned into the black one above instead. They may help to give you a better idea of the assembly and construction. This one shows the edges of the gusset and front and back glued and ready to attach. Shown here before any edge coat was done. Hope that is of some help Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members beltbuckles Posted June 18, 2019 Author Members Report Posted June 18, 2019 thankyou for your answer! and the pictures when you apply contact cement to a gusset, is the gusset completely dry? or is it a bit wet to be able to stretch it better? ( i know you have to let the glue dry before pressing the leather items together) Quote
Members johnv474 Posted June 18, 2019 Members Report Posted June 18, 2019 Not OP but most cements recommend that the leather be clean and dry. If you need it moistened I would dampen from the outside all over but on the inside everywhere but where the cement is. Quote
Members beltbuckles Posted June 18, 2019 Author Members Report Posted June 18, 2019 1 hour ago, johnv474 said: Not OP but most cements recommend that the leather be clean and dry. If you need it moistened I would dampen from the outside all over but on the inside everywhere but where the cement is. thank you! i feel like its a tough situation because if the leather is wet, i can stretch it better, but then i shouldn't glue it (until it dries) Quote
RockyAussie Posted June 18, 2019 Report Posted June 18, 2019 4 hours ago, beltbuckles said: thankyou for your answer! and the pictures when you apply contact cement to a gusset, is the gusset completely dry? or is it a bit wet to be able to stretch it better? ( i know you have to let the glue dry before pressing the leather items together) With this form of construction there is no need for any wetting or stretching. This helps a lot when you want pieces to go where you want consistently. If for some reason you are hell bent on wetting and gluing you can do it somewhat by gluing first then wetting and waiting for it to get nearly dry then warming the glue area up with a heat gun and then attaching together. Only reason I ever did this was when I wanted to stitch soles on shoes and with the hard leather you get in this situation it helps a lot. Are you using a sewing machine to stitch this? It would help a lot if you could show a picture of what it is you are trying to do first. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members beltbuckles Posted June 18, 2019 Author Members Report Posted June 18, 2019 (edited) so i have part side parts and a big rectangle part that gets sown on the bottom and sides of the gusset (then i have a cover on top but that is not in the picture) i would like to be able to glue it in place, but sometimes it is hard to stretch the leather enough when it is dry so i wet it a bit to help. both edges will be facing out to burnish later i could get it wet, and clip it in place, then glue later on when it dries... is that the best option? i would be using a cylinder arm walking foot singer 153 (B?) clone consew 227b i think i used similar ounce (mm) leather last time and it came out bad... so i went and got some thinker leather for the main, and thinner for the sides since i have had better luck with that in the past Edited June 18, 2019 by beltbuckles Quote
RockyAussie Posted June 19, 2019 Report Posted June 19, 2019 So you are wanting to put a round base on the bottom like in this motorcycle tool bag? Or more like the base of this briefcase? Do you have a skiving machine? Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
RockyAussie Posted June 19, 2019 Report Posted June 19, 2019 I just realised that I should have shown the motor cycle tool bag before I stuck the end in it. After thinking about it further I think you may be going for something along this sort of gusset below perhaps. Whether it is folded edge or not does not matter. If this is the shape then the gussets I do start off cut out like the pieces above the bag in this picture. The bottom V is then stitched like this and trimmed close then tapped down to set the open shape. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
