The Adler manual I have is in German English and French, I think off hand, it is an operators manual.
An Adler mechanic here in Australia told me to use the Adler 205-370 manual as the mechanics of them is basically the same. Sadly I found neither of the easy to follow, may be it's just me.
Bert.
Yup, I agree. But, you can get some good information, you just have to pick through it,
Yep  That is an Adler 105-64.   It was the best cylinder arm that Adler had for some time.  Replaced by the 205-64.   The 205-64 is what Adler eventually built the 205-74off off which was later rebadged 205-374 and then 370.  It will sew leather up to 12mm.  Nice machine.
Thank you Shoepatcher. Would you happen to know, would 205-64 or 205-74, or even cowboy 205 feet or plates fit?
The 105-64 is a needle feed + drop feed only machine. Adler 205 triple feed / compound feed presser feet will most likely not work on this machine. You have to look for specific needle feed presser feet. But I yet haven´t seen any after market feet for the Adler 105 /205 needle feed machine. Most likely you have to buy Adler OEM feet. But you can install roller presser foot which slides onto the presser foot bar. The Singer 45K roller foot also works on Adler machines - in case you find one. Picture is an extract from a German Adler 5 Manual.
The Cowboy line includes both Juki and Adler clones. The Juki clone feet will not fit an Adler. But, their Adler 205 clone feet may possibly fit your machine. It is worth your time to inquire at either Toledo Industrial Sewing Machines or Solar Leather Sewing Machines
Posted IMHO, by Wiz
Constabulary, Thank you! I understand what your saying, and am afraid you may be right. I have not yet actually checked on Adler prices, but have read they are very spendy compared to others. I will have to look into the roller foot a little more. You cant really see it in the photos I posted, but the machine currently has a left zipper type foot on it. I would like to have both a right zipper type and a center foot to use as when the situation allows. I would also like to acquire a holster plate, or another standard plate that I can the build into a holster type plate. Just a few things on my wish list. By the way, I think your profile picture is great, always have gotten a kick out of it.
Wiz, Great information, Thank you! I will get some measurements and contact them. Thank you for you writings on leather sewing machines. They are, honestly, a wealth of information!
JD
