Members Sheilajeanne Posted July 11, 2019 Members Report Posted July 11, 2019 (edited) 936 is just a little smaller than 701. You do need bevelers of different sizes, but since the difference between 936 and 701 is quite small, I'd go for the larger beveler instead, if money is an issue. Yes, B60 is an undercut beveler, for lifting different areas of your designs. If you are going to do Sheridan style carving, where you are tooling leaves and flowers, you will eventually need one, though the simple designs you show above likely wouldn't need it. The arrows point to areas of this leaf where you'd use this sort of beveler: Edit: I probably should say this was our project for the third or fourth week of the beginner leather working course at Tandy. My tooling skills have improved since then! Bill, thank you for your patience with me...I will never forget you! God rest your dear soul... Edited July 11, 2019 by Sheilajeanne Quote
Contributing Member JLSleather Posted July 11, 2019 Contributing Member Report Posted July 11, 2019 2 hours ago, Mocivnik said: @JLSleather but 936 and 701 looks same to me? The 936 is HALF the size of the 701. I wouldn't be without the small bevelers -- you can hit it twice where you need to to fill the size of the 701, but you can't hit the 701 in the space of the 936. And the 803 is easily twice as wide as the 701, so on those long, less curvy sections you can move faster. Here's the tools involved here.... 936, 701, 803. And ABHandmade is correct... a smooth tool or two doesn't hurt a thing BTW: I used to have a set of undercut bevelers - long time ago - and also those "lifter" tools with wooden handles. Gave them all away to somebody else who THOUGHT they were needed Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Mocivnik Posted July 12, 2019 Author Members Report Posted July 12, 2019 Ordered both. Thanks God I really HAD to finish my order - otherwise the tool list would never find end :D Quote
