Members Laurajane Posted July 7, 2019 Members Report Posted July 7, 2019 Hi, I am using an adler 167 373 to sew leather handbags. It's a great machine, old but still hums along nicely. I've hit a problem with the foot. It started rubbing on one side. I tried changing the feet over to another set. It doesn't rub anymore but the needle is now positioned very close to the edge of the internal foot hole. I think this is causing an issue when I'm sewing thicker layers. Is there a way to move the the foot to the right without the needle moving too? The needle could maybe move a couple of mm but i think the needle position is ok. Any help or advice would be really appreciated. Thanks Quote
Moderator Wizcrafts Posted July 7, 2019 Moderator Report Posted July 7, 2019 Try rotating the needle bar. It may be eccentric and positionable. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Laurajane Posted July 7, 2019 Author Members Report Posted July 7, 2019 Wizcrafts can you tell me how to do this please? Sorry it may be very straight forward but I'm not very knowledgeable about this machine. Thanks Quote
Members Gregg From Keystone Sewing Posted July 7, 2019 Members Report Posted July 7, 2019 The outside, or lifting presser foot seems cocked off to one side in relation to the needle plate and feed dog. Once you get that lined up, you should be able to center the inside vibrating foot hole where the needle goes through. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members shoepatcher Posted July 7, 2019 Members Report Posted July 7, 2019 Greg, I agree with you. The outside foot is not parallel with the throat plate/feed dog. To correct it, the shaft for the outside foot has to be loosen and rotated. Remove the inside foot before doing this. It has been awhile since I have worked on a 267. Send us a few pics of the back of the head and the left side of the machine with the cover plate removed. We then can tell you what to loosen to rotate the outside foot shaft. glenn Quote
Members Laurajane Posted July 8, 2019 Author Members Report Posted July 8, 2019 Thankyou I really appreciate it! Please let me know if you need any more photos. When I look at the outside foot I can see it's not lined up with the feed dog at all. It also looks like the righthand side of the outside foot sits a bit lower than the left side Quote
Members Laurajane Posted July 8, 2019 Author Members Report Posted July 8, 2019 Sorry about posting the images as separate posts. I'm not to good with technology and my photos seem to be a bit big Quote
Members Laurajane Posted July 8, 2019 Author Members Report Posted July 8, 2019 Ok so I managed to get the outside foot looking alot better by adjusting it via the back but the inside foot is way off. I have no idea Quote
Members Gregg From Keystone Sewing Posted July 8, 2019 Members Report Posted July 8, 2019 How do the other feet line up here? Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Laurajane Posted July 8, 2019 Author Members Report Posted July 8, 2019 I put the internal foot from my welting set on and its perfect! So I'm guessing that means it's the foot thats not right not the machine. So now I'm on the search for another new set. Quote
