Members Bulldogger Posted July 7, 2019 Members Report Posted July 7, 2019 Hello all. I'm new to having a leather sewing machine and new to Pfaff mechanisms. I do ok with my Singer 519 but I'm stumped with this older 1245 Pfaff (706/47). After following the service manual guidance for calibration I was nearly finished when I realized the feed dog and vibrating foot are moving backwards. I am sure I'm rotating the balance wheel correctly (towards me like most machines) since the bobbin assembly is clearly rotating correctly. If I push the reverse lever upwards the machine feeds forwards, which is good I guess (it "reverses") but no less confusing. The machine was old and sitting in a shed a long time. I took off external fittings for rust removal, but none of the main mechanisms or lever arms, and dosed her well with kerosene. After a while she started moving freely and now turns over fine. It is very possible (and my working theory) that attempts by me and previous acquaintances to turn it over while half frozen caused an internal timing error. Unfortunately the service manuals I've found online are not assembly manuals, they assume a working machine only in need of calibration, more or less. Has anyone else seen or heard of this and can you offer any advice where to look please? There is a service center near me, if I fail in my attempts, but I've spoken with them in the past and was rubbed the wrong way. I'll take it there if I must but hope I can DIY this. Thanks in advance. Alex Quote
Members Gunnarsson Posted July 7, 2019 Members Report Posted July 7, 2019 Any chance the reverse lever has lost a spring or something like that, so it has fallen to reverse position? Quote
Members Constabulary Posted July 7, 2019 Members Report Posted July 7, 2019 is it just feeding or is it permanently sewing backwards? If it is just feeding backwards and the stitch length lever is in correct forward position it could be a motor failure. Quote
Members Pintodeluxe Posted July 7, 2019 Members Report Posted July 7, 2019 Are the upper and lower shafts synchronized? In other words do the timing arrows align under the machine? This is a common problem, and should be pretty easy to sort out. Quote
Members Bulldogger Posted July 7, 2019 Author Members Report Posted July 7, 2019 Gunnarson, the reverse mechanism appears intact, and it reverses the direction, just that it’s backwards Constabulary, I don’t have it on a motor yet, I’m turning it by hand so not a motor problem. The stitch length lever is positioned correctly. Pintodeluxe, where are these timing marks please? That sounds like a distinct possibility. Lastly jere are a couple of photos, in case they help. Bulldogger Quote
Members Pintodeluxe Posted July 7, 2019 Members Report Posted July 7, 2019 (edited) Nice looking Pfaff. Wow that thing is clean. If you don't have a paper manual, pull it up online. I think it shows the timing arrows in the manual. It's been a long time since I had a 1245, but most machines have some sort of synchronization arrows under the machine head, to the right of center. Turn the handwheel toward you until you see an arrow. It should come into alignment with a second arrow. If it doesn't, the internal timing belt was probably installed incorrectly, ie: like 180 degrees out of phase. Edited July 7, 2019 by Pintodeluxe Quote
Members Bulldogger Posted July 7, 2019 Author Members Report Posted July 7, 2019 Thanks pintodeluxe, I'll go look. I don't recall any timing marks in the manuals I found but I didn't look on the shafts for arrows so I will Bulldogger Quote
Members Bulldogger Posted July 7, 2019 Author Members Report Posted July 7, 2019 (edited) I cannot find anything that look like timing marks or arrows on the shafts underneath or on the pulleys. My manuals do not include instructions on replacing the internal drive belt or timing the pulleys... I will search for more manuals. Most manuals online are for newer machines not mine. Bulldogger Edited July 7, 2019 by Bulldogger Quote
Members shoepatcher Posted July 7, 2019 Members Report Posted July 7, 2019 Sounds like the feed eccentric is 180 degrees out. No timing marks underneath a 1245. Can you upload a quick video of the machine being turned by hand so we can see the feet and feed dog in action? glenn Quote
Members Bulldogger Posted July 7, 2019 Author Members Report Posted July 7, 2019 Thank you shoepatcher, you were typing this while I was sweating in the garage one more time through the calibration steps. The "lifting eccentric" for the vibrating presser foot was indeed way off! This was the most rusted part in the machine. I found acorns in the recess in fact. I think a mouse had been living inside at one time. Some bravery with a gentle punch freed up the eccentric and allowed me to observe its effects. Once I brought it noticeably far around the shaft the vibrating presser foot reversed its motion and the feed dog obliged. I then recompleted the entire calibration order to realign everything. It appears ready to mount to a table and motor. I had a stiff piece of 1/8 leather next to me on the workbench, which I use as vise jaw pads, and I hand stitched a nice long bead of holes in it. (Didn't have thread or bobbin handy) Next I will mount it and perform the thread tension and alignment steps and see how it will stitch. Thank you all for your encouragement! Bulldogger Quote
Members Bulldogger Posted July 7, 2019 Author Members Report Posted July 7, 2019 One last issue, the dreaded “mystery leftover” part... It doesn’t appear in any of the photos I took prior to cleaning and calibrating the machine. Part number stamped on it is 176332 Any ideas? Thanks again Bulldogger Quote
mikesc Posted July 7, 2019 Report Posted July 7, 2019 (edited) Part is number 91-176 332-25 attached is parts list ( pdf ) with diagrams for your model..diagram is on page 12 towards the bottom.. from the take up spring assembly on the front of the machine..AFAICT HTH 6mdl64b0.pdf Edited July 7, 2019 by mikesc Quote
Members Bulldogger Posted July 8, 2019 Author Members Report Posted July 8, 2019 Super! Thanks mikesc, it does look like part of the tensioning and take up assembly. Bulldogger Quote
Moderator Wizcrafts Posted July 8, 2019 Moderator Report Posted July 8, 2019 I think that bracket is to control the travel of your check spring. Quote
Members Constabulary Posted July 8, 2019 Members Report Posted July 8, 2019 14 hours ago, Bulldogger said: After following the service manual guidance for calibration I was nearly finished when I realized the feed dog and vibrating foot are moving backwards This sounds very strange and I don´t know what a Singer 519 is so just to clarify: Moving backwards in your case means the material is feeding towards you when the lever is down and you turn the hand wheel towards you and it is feeding away from you when the lever is up and you turn the hand wheel towards you. Is this what happens? I know question may sound stupid but you never know... Quote
Members Bulldogger Posted July 8, 2019 Author Members Report Posted July 8, 2019 Constabulary, that is what was happening. It was very odd. It seems ok now that I moved the feeding eccentric for the vibrating presser foot about 100 degrees on its shaft. I will connect the motor this week and test the stitching abilities. I incorrectly noted my Singer model, it is a 591D200A. Bulldogger Quote
Members Gregg From Keystone Sewing Posted July 8, 2019 Members Report Posted July 8, 2019 16 hours ago, shoepatcher said: Sounds like the feed eccentric is 180 degrees out. No timing marks underneath a 1245. Can you upload a quick video of the machine being turned by hand so we can see the feet and feed dog in action? glenn Quote
Members Bulldogger Posted July 8, 2019 Author Members Report Posted July 8, 2019 Thank-you Gregg. That calibration step was challenging, as the feed dog never wanted to sit still as indicated. Once I got the vibrating foot set correctly, the step you show was easier to get right. Here is the step that I had very miscalibrated. The eccentric, number 2 on the figure, was spun on its shaft and very out of cal. Bulldogger Quote
Members Gchenoweth Posted June 13, 2021 Members Report Posted June 13, 2021 I just acquired a Pfaff 1245 that is probably 50 years old and I am having the same problem with the machine going backwards with the reverse lever down and forward with it up. Can someone help me understand what I need to do to fix this. I could not follow the thread to understand where the problem is. Thanks, Hill Country Gal Quote
