Members katit Posted July 7, 2019 Members Report Posted July 7, 2019 To be precise it's about 138WSV102HP, but it shouldn't matter much for adjustments. After thorough cleanup I found that machine is out of adjustment. At least needle bar is not in tune as needle wants to hit about 1/2 in front of feed dog holes. I decided to start from beginning. Couple questions came up right away: 1. Belt is 1/3 off. It's on good on top, but in a bottom it want's to stay off. Any idea/suggestion on why and how to fix? 2. Alignment mark on bottom shaft is not present. Picture shows where I have eye at the top and I see only faint mark on a collar kind of corresponding to mark on a chromed bracket. Not even sure if it's a mark. Blue arrow on picture. Correct? 3. What is a procedure with stitch adjustment on this machine? I need to do that in order to do other adjustments but have no clue where 0, 8, etc is and how to operate it? I don't have dial on turn wheel like manual indicates. Machine from a factory, so it's probably preset.. I assume #1 and #2 loosening mechanism and #3 to do adjustments? Any tips? Like how many revolutions from MIN to 8spi, etc? Those are things that I have trouble with at a moment, all other adjustments look like regular 111 stuff explained in many places. Quote
Members nylonRigging Posted July 11, 2019 Members Report Posted July 11, 2019 The Top belt drive pulley has sides, so belt rides in a Chanel, so it cant walk right or left . . On the belt not riding on the bottom drive pulley and walking off to side . The surface might be worn and making the belt walk off . ( best Guess ) .. surface wear/friction over years . Surfaces do not always wear-out even and flat . I have seen this before . As for the rest of questions, cant comment as I have never owned that model . . Quote
Members rk5n Posted July 14, 2019 Members Report Posted July 14, 2019 (edited) I have a 136w110 which is similar, but shaft driven instead of belt driven. To adjust the stitch length, loosen #2, then turn #3 clockwise to decrease stitch length and counter-clockwise to increase. My machine doesn't have screw #1, just double check that it doesn't clamp the sliding eccentric in place like #2 does before adjusting. As far as the needle hitting a half inch in front of the feed dog holes, are you sure it's the needle bar and not the post that's mis-aligned? Edited July 14, 2019 by rk5n Quote
Members katit Posted July 14, 2019 Author Members Report Posted July 14, 2019 Thanks for replies! @rk5n See picture. I'm sure it's needle bar. Post is OK, but distance between needle bar and feet bar is too big and "wear" line is about 3/8 out(arrow) when it's all way back. So yes, it's somehow got out of whack. I didn't touch any settings yet, want to start from beginning. Quote
