Hello all!
So I had an incident with my French edge skiving tool the other day..  I recently moved up to using top grade hides and the level of toughness compared to the Tandy special is amazing!  But... That being said my edge tool is no longer refined enough to cut the high end hides and I ended up slipping off the leather and getting a nasty gash on my finger.
I like to keep my tools sharp and up too this point I thought it was sharp enough.  I strop the bottom edge and use Dremel buffer wheel with green compound to get to the hard to reach upper edge.  Upon closer inspection I realized the top bevel isn't even and I need to do some significant material removal to true up the edge.
Does anyone have any suggestions on how I can't modify the bevel without ruining the tool? Any sharpening and honing tips would very much be appreciated!
Thanks and God bless!
I assume that it's straightforward enough to work on the bottom of the tool with stones, if necessary,  and a strop in the usual way. But as you've mentioned the problem lies with reaching the inside of the tool, and the bevel
Depending on how much metal you need to remove, start by clamping the tool in a vice and working on the bevel with a needle file. You would probably only need a flat file
You could then make up a narrow file or 'wand' by gluing wet & dry paper to strips of wood that are just the right size to fit inside the tool, and polishing the bevel
Alternately make up strips of wood as above, but glue them to some scrap wood to make raised strips that the edger will fit onto. Remove the edger from the vice and sharpen it on these homemade 'stones'.
In both of those cases, work your way from about 400 to 1200 grit in in increments of 2 to 300; lubricate the paper with water, perhaps containing a small amount of washing up liquid/dish soap, or clear window cleaner. Only work the tool away from the edge
Then follow up with a small strip of leather in a similar way
Have a look at this video - 'How to sharpen French Edger' by Leathertoolz
I would not be tempted to use a grindstone on your Dremel as it would be so easy to go to far and damage the edge or burn the steel
I remember reading one leathercraft book which described a French Edger as 'probably the most dangerous tool in the workshop'.
Edited by zuludog
Here is a couple of videos that may help too
Just remember to keep your free hand behind the cutting edge, many experienced people have a healthy respect for this tool.
.https://youtu.be/hbQZt_VduEI
https://youtu.be/dej8BH1DFgs
Hope this helps
JCUK
Edited by jcuk
Over the years iT FOUND IT TO BE a worthwhile investment to get a collection of stones to just fit inside of my french edgers
Jcuk has posted a link to one of my sharpening videos.   I thought this might also be of use
On 7/11/2019 at 5:17 PM, Michellleatherworks said:
Hello all!
I use this to strop my french edgers.
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.25442e8dmFv5qh&id=561196909516&_u=r2pk7i5fa6b3
Never had to repair the edge before but I'm guessing I could probably do it on this with low grit sandpaper.
It may be more worthwhile to invest in a better tool rather than spend a lot of time on a cheap tool? If it is a cheaper tool.
Kevin Lee from Crazy Cut Leather has some nice french edgers for about 40 bucks.
.02
  • 8 months later...
The best way to hone the top edge of a French skirt shave is once you have the inder sode done on a strop, to take any upward facing burr off is cut a strip of leather,  bridle keather will be fine,  make it the same width as the inside of the flat blade so it sits snug between the forward facing guides, then with this strip, run it through you splitter and thin it down so you have a strp about 2 MM thick and use the strip that was the flesh side,   then on a spare bit of bench, tack one end of the strop so it hangs down and with the spilt part facing upards.   you can use the leather plain or rub a bit of finest jewellers rouge on it,   then what you do is turn your French skirt shave upside down,  and lay it on the leather strip near to where you tacked it to the surface and have about 12 inches of strip hanging down,  press the blade onto the leather with your thumb and curlyour fingers underneath to hold the strip into the blade,  then what you do is run the blade down the strip of leasther while retianing the striop onto the blade with your finger and thumb. You dont want to have much angle, just enough so the strip of leather runs over the edge as you run the blade down the strip.  I have different width strips for dofferent width skirt shaves. Once you've done thos then you cn go back to the strop with fine jewellers rough to finish off the under side. Repeat if necessay.  It will take you a bit of practice but I assure you once you have got to grips with it this will hone and keep your skirt shaves in tip top condition mpre so than ever.  Let me know oif you want pictures, will get some to you.
For edge shave tools, the best way to hone inside the little groove is a similar  methid but what you do is cut a bit of tiger thread which is best for this,  not too thin either, cut a length of thread about  18 inches long,  tie one end of the thread to anything you have handy, like a hook in a bench a drawer handle etc,  then rub a little bit of  fine jewellers rouge onto the thread, then with your edge shave, turn it upside down, then near where you tied the thread,   place the thread in the groove and hold in place with your thimb and finger and then run the tool down the thread,  not too steep an angle and just enough so the thread runs over the edge of the cuttng edge, do this say 4-5 times if its burred,    thios thread method will really sort the edge in the groove, then put the under side on a leather strop and draw it backwards, then re run it on the thread,   again with practice, this is the best way to sharpen edge shave, it works on hollow ground edge shaves as well
