Hello. I am so thrilled to have found this forum. I have spent hours poring over the information here, and am learning so much. Thank you! I sew handbags, totes, etc out of salvaged sails, horse tack, marine vinyl, and waxed canvas.  I currently sew on a Sailrite LSZ-1 and a Viking 6270.  I push these machines perhaps a bit past their limits. I am looking for a cylinder arm industrial machine that will allow me too tackle some more heavy duty work with these materials.  I found this Yamata on eBay. I am wondering what you guys think compared with the Cowboy CB227R and the TechSew 2600?  This one is cheaper, even though it does require at home assembly. I am pretty handy, and I’m married to a mechanically minded individual. I am not really afraid of the assembly. I just want to make sure I get the right machine for the job. Any advice is greatly appreciated. Thank you !
https://www.ebay.com/itm/Yamata-GC335-10-Arm-Cylinder-Bed-Walking-Foot-Sewing-Machine-Stand-Servo-motor-/323503216189?_trksid=p2385738.m4383.l4275.c10
Since you are on the west coast of the US it maybe worthwhile to checkout other clones like Artisan Sewing Machines ( https://www.artisansew.com/cylinderarmandpostbedmachine.html ). Shipping should be less and closer dealer support. Since this is a fine layout of cash, I would advise you to make a road trip with some of your material to dealers on the west coast. Test ride a few machines and see what works best for you and your work ( new or good used, price, flatbed, cylinder bed, clone or brand name (Juki, Pfaff, Alder). Buy Once, Cry Once.
kgg
kgg
Thanks for the pointers! Ideally, I’d like to spend less than$1,500. However, I’m finding that difficult with the perks I’d like the machine to have.  That’s why this unassembled Yamata looks so appealing. You’re right, though. I don’t want t regret what I buy!! I just went to the Artisan site and will dig around there. Thanks again!
Edited by CalypsoReCreations
Forgot to include relevant information
Yamata and buying off Web. like Ebay or Amazon . It is no doubt a good machine and it is not hard to put it together and get running .
( You Should ) get a Tech. to fine-tune and time 'for your application' and for your peace of mind after you get it set-up and running . Well worth paying-$ a hour of his time and see your starting off with good wear pattern and have it running good.
That Yamata ( spec. Sheet ) also might be a little bit exaggerating on the #207 thread and 135x17 needle ( rotary hook ) . (imho) that 207 is maybe? pushing it, and It sure be suited better up to #135 thread size .
-->  Research what presser feet it takes ( are they common ) easy to get . It Always nice to have extra sets to cut and shape to your needs .
Also in that Add Link you posted say's,  FREE 'standard' shipping all way from Florida ??? holy crap that will save you money ...
For that price you buying . I can just about guarantee that they not even looking and touching those machines they shipping out to you. they sending them out in same boxing they get them in from there distributor.
It's a trade-off . You getting a machine that is a good design and will work for you for years ( At Lowest Price ) . But you have to pull it out of factory crate and clean-up, put it together and work the bugs out of it and then get timing set-up to your satisfaction .
Artisan ( as mentioned also ) , is good also on there cylinder beds machines or flatbed. and it nice that if you have question or need a part . that all you got to do is call them down in Cal. and you will get a real human being to talk to you .
I have there newer version 12" arm Artisan 3200 and run it for a lot of hours and I got absolutely no bitches about it .
( Machine Repair ) I use/call few guys that off in Portland, Salem and Vancouver for mobile Tech. repair . But You over in Newport on the coast, where/who you call for any Mobil repair over on there ?
Thanks for all the info! What a help! I know of no one to call for mobile repair here. I work on the machines myself, but there is a lot of Sailrite tech support via video and customer service. My Viking is pretty straightforward, and I do all the work on it myself resourcing the manual and YouTube. I’d prob have to take any industrial machine I bought into Eugene, Lincoln City, or Corvallis for a serious repair. Also, it Sounds like setting up the Yamata will be more daunting than I originally thought. I need to do some digging and see if there’s a tech in a nearby town that could come help me get it tuned after set up. Still thinking about the Cowboy, though. Thanks again!
What are the perks you are wanting? Personally, if it was me I would narrow down the needs, wants, pros and cons against what you are mostly sewing. You don't want to buy a machine that you are only going to need occasionally. You maybe better off buying a brand name (Juki, Pfaff, Alder) flatbed machine and then later buying a used cylinder, patcher or post bed machine for the occasional usage times or vise versa. It is going to come down to the best machine for most of your sewing needs since one machine will not do everything.
Purchasing the Yamata maybe a good clone buy, which is based on the PFAFF 335 design, or you may need to become a sewing machine tech to get it running properly. I have seen clones that will sew a good stitch and others that sounded like a bucket of bolts banging around. For a couple hundred dollar machine I would expect things not to be perfect. Then after I reach a certain dollar point the machine has to sew flawlessly as well as having a fit and finish equally as good right out of the box.
kgg
From the description in their ad, you are responsible for what happens to the machine after you receive it. It is drop shipped untested in a factory sealed box. You will have to handle any adjustments and repairs at your own expense. There is likely no support offered by the reseller.
Posted IMHO, by Wiz
Hi, Wiz! I was hoping to see you here after reading your other post responses! I’m realizing the Yamata is probably not the best idea as I am not a machine tech, and do rely on customer support with my other machines. I sew thicknesses of up to 1/2 thick of mixed textiles (usually canvas, Dacron). Sometimes, when attaching a leather strap, I sew the leather directly onto the Dacron and canvas combined. I use salvaged horse tack (reins, bridles, chest harness, etc) for my straps. I need a machine that can handle the load, but won’t tear the bag apart. I really want a cylinder arm for the roll top finishes on my up cycled sail bags. My thoughts are the Cowboy CB227R or the TechSew 2700. I am also looking at a used Singer 153 B8B listed here:
https://www.ebay.com/itm/SINGER-153-B8B-CYLINDER-BED-WALKING-FOOT-REVERSE-110V-INDUSTRIAL-SEWING-MACHINE-/133109582798
There is so much to consider, and I feel a bit overwhelmed. I know that I want a cylinder arm, compound feed machine. Now, it’s just about deciding which is too much power, and which is not enough. Thank you for your help!
kgg
Thanks! I have made a list of things I need out of my next machine. A cylinder arm is what I think will really help and fill the work gap in my studio. My Sailrite can handle a good deal, it just falters on the finishes of my work (it struggles over varying thicknesses and over major seams). I do a roll down top finish in my sail totes. The Sailrite can’t evenly walk the thickness through (even with the walking foot). My Viking handles all my lighter work beautifully. Thanks for the suggestions about the Yamata. You have a good point about paying a dear price and wanting it to work effectively. Also, I think I want to buy something I can have support for. I appreciate all the feedback!
Spelling
Without seeing your sail totes, have you thought of using a binder attachment with double folded binding material. Maybe using a ripstop type material for the top edge which would give a nice clean edge without the bulk of material that you are folding over. If possible could you post a picture of your bag maybe someone could offer alternative sewing methods that would reduce the amount of material you are trying to sew through which then may affect your machine selection.
kgg
