Members Woldbill1962 Posted August 26, 2019 Members Report Posted August 26, 2019 (edited) Hey everyone, I know this has probably been asked a million times, but can I ask one more time :-) just starting out, so which kit do you think is best ? Looked at Tandy, ebay, amazon and others, but not really which I should start with. So any advice will be very helpful. looking forward to your replies. thanks Bill Edited August 26, 2019 by Woldbill1962 Quote
Northmount Posted August 26, 2019 Report Posted August 26, 2019 4 hours ago, Woldbill1962 said: Hey everyone, I know this has probably been asked a million times, but can I ask one more time :-) just starting out, so which kit do you think is best ? Looked at Tandy, ebay, amazon and others, but not really which I should start with. So any advice will be very helpful. What type of items do you want to make? There are many routes to go. Are you interested in tooling, sewing bags, making belts, etc? Can't tell you what tools you need until you tell us what you want to make. Tom Quote
Members Woldbill1962 Posted August 26, 2019 Author Members Report Posted August 26, 2019 Hey Tom, thanks for the reply. My plans are to make holsters, knife sheaths, wallets, purse for the wife unit, motorcycle tool bag, maybe a backpack etc. Will prob be sewing and lace work, would like to try my hand at adding tooling to each project. To green to know if any tool kit that Tandy and others put out, will come close to what I really need. Dont have deep pockets, so want to get enough to get started and progress from there. Thanks for your help ! BILL Quote
Northmount Posted August 27, 2019 Report Posted August 27, 2019 A lot of what you want to do doesn't necessarily involve tooling. So you could drop that portion until later and learn to cut, assemble, sew, rivet, etc. using hand tools. Need patterns and a sharp knife - a box cutter will do to start with Something to mark out stitches with, a good sewing awl with very sharp diamond point, harness needles and thread. Some contact cement will help hold thing together while sewing, or for attaching a lining. If lacing, will need lacing chisels, single and multiple prongs for the size of lace, lacing needles (I use a permalok) and some lace. Maybe a good place to start might be a pre-cut kit where you are just assembling and either lacing or sewing. Then you can get a feel for some of the work and move on from there. Others will be along with some specifics and ideas for you too. Tom Quote
CFM Hardrada Posted August 27, 2019 CFM Report Posted August 27, 2019 (edited) Ian Atkinson has put together a nice list of basics: Recommended Leather Tools. Worth checking out since he seems to focus on what you too want to focus. I'd buy items individually and avoid kits: with kits you're likely to end up with tools you won't use, in addition to the low quality issue if you buy the "budget" ones. Edited August 27, 2019 by Hardrada Typo Quote
wizard of tragacanth Posted August 27, 2019 Report Posted August 27, 2019 (edited) I second the recommendation to avoid kits. You would get too many things that may be worthless to you, and often cheap versions of what you will eventually want. As much as I like Ian Atkinson, and it won't hurt to watch his video... be careful. He discusses maybe 25 tools for beginners but you should only be buying a few tools in the beginning and only those that you need to get you through the project. You will need some cutting tools. You can start with a box cutter for large pieces and something like an x-acto knife for smaller pieces. If you do not have these already, I would recommend getting the ones with the snap-off blades so that you will always have a sharp blade. Dull blades are very difficult and disappointing and can result in injuries more easily than a sharp blade. Get something like the Olfa brand, 9mm and 18mm. Lowe's or where ever. You will need leather, of course. Holsters will need something in the range of 8-10oz veg tan, or two layers of 4-5oz if you plan to line it, gluing the layers back-to-back. You will need needles and thread. Try #2 Harness needles first. You will want waxed thread for hand-stitching (0.8mm - 1.0mm) nylon or linen thread. Buy the color that you need for your first project. Ultimately you will probably have several colors on hand. Black, brown and white are the most used colors, but just buy one for now. You will need a way to mark your stitch spacing, 5-6 stitches per inch (spi) most likely. Then you need a way to make those holes. I started with a drill but now I use stitching irons (one, two and four tines). You don't necessarily need dye right now. Many people leave the leather the natural color but if you dye it, I would suggest dark colors to start, like black or dark brown. Fewer problems. You may want to top-coat or finish the project. The cheap but very popular way is a 50/50 mix of Mop & Glow with water. Apply in a very light coat or it becomes problematic. Before you buy or do anything, watch some YouTube videos on holster making. Here is one: https://www.youtube.com/watch?v=SFsXw3gabqkYou will want an edger, if you watch the above video, Hank shows how it is used. You will want some sandpaper and a sanding block. 120 or 150 grit up to 600 or higher to finish your edges. I like the Warner sanding block https://www.lowes.com/pd/Warner-Sanding-Block/3078153 It is small, inexpensive and very useful, having a curved edge, wedge and flat side. You can use water to burnish the edges but Gum Tragacanth is better and Tokonole is still better, IMHO. You will need rubber cement. I prefer a small bottle of Weldwood because if I am not doing many projects the glue will dry up. It is MUCH better when it is fresh! Lowe's or anywhere. Some things should be bought in sets, such as round drive punches, but again, wait until you need them. You need a cutting surface if you do not have one. Kitchen cutting boards, like the white poly ones from Walmart will do for starters. You will probably want a Poundo board at some point, maybe soon. https://www.tandyleather.com/en/product/poundo-boards Choose the size based on how big your expected projects and work area are. I only do holsters, so 12"x12" is enough for me. Same for Quartz slabs. https://www.tandyleather.com/en/category/quartz-slabs which I use to back up the poundo board for using stitching chisels. Tandy Pro Line Diamond Chisel 2mm spacing, for 6 spi https://www.tandyleather.com/en/product/pro-line-diamond-stitching-chisels You will find out that these things are both a curse and a blessing. Maybe start with a drill press or Dremel on a stand. I cannot remember the bit size, I think it is 3/64". So, you may have much of this already and may require only the "specialty" leather craft tools, hopefully. I probably left some stuff out, we will see. nick Edited August 27, 2019 by wizard of tragacanth Quote Wisdom from an old Missouri farmer, my Grandpa: If it's not sharp, it's not a knife.
Members zuludog Posted August 27, 2019 Members Report Posted August 27, 2019 (edited) Yes, the question about tools for beginners has been asked several times before, just look through past Threads on the Getting Started and Leather Tools sections There are also some videos about beginners tools on YouTube, though you will notice that each one is slightly different Wizard's suggestions are good, but before you buy anything I suggest you look at videos on holsters, sheaths, and the rest of the items you've mentioned. That way you will see how other people make them, the tools they use, and how they are used. I make mostly knife sheaths from 3mm vegetable tanned leather. Here are a few things to get you started - A cutting mat, the usual green thing from a craft or hobby store; get the biggest you can manage A utility or craft knife A stitching chisel. Tandy Craftool 2 prong 4mm spacing. In theory they replace an awl, but when you have a few thicknesses of leather to penetrate you need to do extra work with an awl. You can start with a steel hammer if you already have one, but this will damage the tool if you use it regularly so you will need a soft hammer/mallet - nylon, hide, wood, but not rubber as this will bounce too much Needles; Rocky Mountain Leather Supply sell an assorted pack of John James needles Thread; Tandy ready waxed nylon thread is good & cheap, or see what your local craft shop have Dividers, to set the line of stitching and it's distance from the edge; or you could use the stitching chisel An awl. Don't be tempted by the 4-in-1 awl sold by Tandy, and others, it's expensive and not very good. Just get a simple, ready mounted, fixed blade awl An edge beveller; Tandy Craftool size 2 is a good one to start with. It's fairly cheap, and easy to use & sharpen A tube of contact or general purpose glue An edge burnisher Beeswax Even if you get disposable blades they can be improved by a bit of extra sharpening, plus you will need to sharpen the awl. There is loads of information about this - various stones or wet & dry paper, and making a strop is just about the easiest piece of leatherwork you will do Have look through the websites for Tandy, Rocky Mountain Leather Supply, and other leather craft suppliers. Even if you don't buy anything from them you will see the sort of things that are available Edited August 27, 2019 by zuludog Quote
Members Woldbill1962 Posted August 27, 2019 Author Members Report Posted August 27, 2019 WOW ! Thank you for all of the great information and advice. Folks like you are what makes this forum great. Looks like I will be putting a shopping list together based on your advice and wisdom. Will also be spending some time on YouTube gathering some information and knowledge. Thank y,all so much for taking the time to help @ Bill Quote
Members arashikage Posted August 27, 2019 Members Report Posted August 27, 2019 To piggyback off of what zuludog said, i would suggest looking up Andrews Custom Leather on youtube. He has a lot of good videos and you can get a feel for what you will need and what you may eventually want to get. The only thing I would add is don't actually buy a quartz slab unless you have to. Check with any kitchen remodeling company near you if they have any samples or sink cutouts that they are getting rid of. I got a 12" x 12" x 1.25" slab for free. Quote
wizard of tragacanth Posted August 27, 2019 Report Posted August 27, 2019 (edited) 5 hours ago, Woldbill1962 said: ... Will also be spending some time on YouTube gathering some information and knowledge. Yes, as zuludog said, watching videos is really the first step. Do not buy anything until you have watched several tool selection videos and some building videos. There are dozens of helpful videos on YouTube. Watch Nigel Armitage, Ian Atkinson and Sam Andrews... you will be amazed at how much you have learned in such a short time! Edited August 27, 2019 by wizard of tragacanth Quote Wisdom from an old Missouri farmer, my Grandpa: If it's not sharp, it's not a knife.
