I just purchased a Cobra Class 4. After the first bobbin, the machine seems to be making a pretty good "clacking" sound coming from movement in the shuttle. Is this normal? Is there an adjustment? Can someone tell me what is happening?
The video was just the machine running with no top thread. It is louder when I am actually sewing.
Thank you,
Carl
I do not have a Cobra Class 4, but I have an Adler 105 and it uses a similar bobbin system and to me it sounds normal.
May be, putting a few drops of oil in the movement might quiet it a little, but it sounds normal to me.
Bert.
Edited by Bert51
spelling
Yeah, that's not a "direct drive" system... there's play in that shuttle/bobbin case area, which pretty sure is the "slap" you're hearing. Looks like the timing is fine... no issues there.
5 leather patterns
Put a few drops of oil in the shuttle race.
Are you loading the bobbins so the thread feeds counterclockwise? That may reduce some of the bobbin slap.
Did you know that you need to remove the faceplate occasionally and put a few drops of oil into each tiny oil hole in the moving parts inside the head?
Posted IMHO, by Wiz
When replacing a empty bobbin or changing thread colours, I normally give it a few drops of oil.
Bert.
Thank you all for your help. I will make sure to keep the race oiled and clean. I am sure I will learn to get used to the sound.
Wizcrafts,
I will definitely oil the race. I do have the bobbin thread feeding counter clockwise. Thank you very much for the response and advice.
That sound is completely normal. I have two Cobra 4's. One about 6 years old and one 2 years old. That is how they sound. It is the nature of an oscillating shuttle.
I have my bobbin, so when you pull the thread, the bobbin turns clockwise.
Bert.
I just found this, which is different to what I do.
Bert
