CFM Frodo Posted September 7, 2019 CFM Report Posted September 7, 2019 my thread broke, i noticed it was frayed then pop. So, instead of cutting all my work out, I stitched over the broken thread with the other thread, then went into the same hole downstream of the break i very carefully, coated that thread with glue will his fix work? Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Contributing Member fredk Posted September 7, 2019 Contributing Member Report Posted September 7, 2019 I'm not exactly sure just what you did but usually when a thread breaks, go back about 3 stitches and just start sewing again. If you are doing two-needle saddler stitch then the broken thread will be locked into its holes by those three stitches. Just trim the broken thread off real neat. Glue on it helps but is not necessary with this method Quote Al speling misteaks aer all mi own werk..
