chiefjason
S&W Bodyguard .380 AIWB
Worked this up for my wife to try out.  First time using the Utiliclip.  Really neat option, especially since she does not like belts.  Added the mod wing as an option when I list it for sale.  5 oz leather which is a bit thin.  If I sell any I'll add another layer down the back to stiffen it up a touch.  Wanted to try something thinner than I'm used to working with.
What does the arm on the left do?  Is it kind of a support piece?
Todd
Todd
Pushes against the pants or belt to help push the grip in more.  Basically twists the holster into the body.  I've found that if you short the reinforcement a bit to move it forward more and not just flat you can accomplish something similar.  It forces the clip to twist slightly as it molds over the top of the slide a bit which also forces the grip into the body.
That's a nice looking holster. I'm sure that will be a good seller for you.
Thank you. That makes sense.
Todd
