Members TheNorthldahokid Posted March 1, 2020 Members Report Posted March 1, 2020 On 2/21/2020 at 6:15 PM, AmyMarie said: Have you had any issues with the black rubbing off when it gets wet? That's the new problem I am running into. I've oiled it before then dyed, when I went to burnish the edges with water the dye started dripping off! I have been rubbing it as much as possible to try to get the excess pigment off but the second water touches it, it is running like crazy! AmyMarie, Sorry about taking so long to respond. But to answer your question NO, I have not had any problems with the black rubbing off. In fact I had just dyed some pieces for testing and when I saw your question I got a cloth soaking wet and started rubbing those pieces. I had a little bit, like very little bit mostly just excess pigment I think, but nothing like what you are describing. I am using pro-dye though, I do remember having a bit more trouble with the regular dye lifting off afterwards, one of the main reasons why I switched from the regular to the Pro-Dye. I also oiled before dyeing, hope this helps. Quote
