Members torrbuidhe Posted November 15, 2016 Members Report Posted November 15, 2016 On Saturday November 12, 2016 at 6:29 PM, Wizcrafts said: Sticks; Have you read about the Family Sew servo motors? I have to believe that somebody in the UK sells this brand. This motor starts spinning at 1 rpm if you so desire. It doesn't have a lot of torque at the slowest speeds, which is why many users add a speed reducer. I have this motor powering a big Cowboy CB4500, through a 3:1 speed reducer. I can sew 1 stitch every 8 or 9 seconds if I had reason to do so. Once in motion it penetrates the thickest stack of leather (unless the belts slip). The same motor without a speed reducer powers my long arm walking foot machine. I can hold it at a steady pace of about 1 to 1.5 stitches per second at the low end, with the speed limiter all the way down to 350. This looks like the Family Sew motor here - http://www.anglosewing.co.uk/anglospeed.html No price though Neil Quote
Members dikman Posted November 15, 2016 Members Report Posted November 15, 2016 The smallest pulleys I've seen are 45 mm (that's what I use). I'd fit the smallest pulley I could to the motor, regardless of whether or not a reducer is fitted. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members dikman Posted November 16, 2016 Members Report Posted November 16, 2016 (edited) Yeah, most sewing machine pulleys tend to be 15mm. I had to sleeve one for a reducer I made so it shouldn't be too much of a problem. I drilled and tapped the pulley to take a couple of set screws 'cos I couldn't use the keyway to lock it in place. Edited November 16, 2016 by dikman Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Constabulary Posted November 16, 2016 Members Report Posted November 16, 2016 I just have checked the last Jack Servo I bought from CS it has a 15mm shaft but that is the 750W w/o NPS, the other with NPS I bought has a 12mm shaft as well - don´t know why that is. Just wanted to have it mentioned. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members gigi Posted December 4, 2016 Members Report Posted December 4, 2016 Finally we managed to have a potentiometer pedal, using scrap material around the home. It is not the best but it serves the purpose. There is plenty of room for improvement. . The control of the machine is much better now. Locked the clutch on engaged position and now the motor is permanently connected to the machine. (The VFD is stopping the motor; after that motor is turning freely). Second video shows the setup is working also with veg-tan leather 7 mm with 138 thread (20 metric). (It's just a test: the machine is not a heavy duty subclass.) Quote Houston, we have a problem
Members brmax Posted December 4, 2016 Members Report Posted December 4, 2016 Excellent! ? curious what is the signal voltage 5? to the treadle switch Seems it has to be different and reduced for the electronics Floyd Quote
Members gigi Posted December 4, 2016 Members Report Posted December 4, 2016 Thanks! Pedal provides variable voltage 0-10V, 10mA max to the VFD. Quote Houston, we have a problem
Members TinkerTailor Posted December 4, 2016 Members Report Posted December 4, 2016 That is a winner. Quote "If nobody shares what they know, we will eventually all know nothing." "There is no adventure in letting fear and common sense be your guide"
Members Constabulary Posted December 4, 2016 Members Report Posted December 4, 2016 Mad electric scientists! Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members dikman Posted December 5, 2016 Members Report Posted December 5, 2016 Well done! Now that you've proven the concept works you can make a better pedal.(Maybe ). Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
