I have a juki ls 1341 cylinder bed sewing machine.  Is there much difference in the 135x17 (standard for the machine) and the 135x16 needle system?
135x17 is a needle for cloth / woven materials and 135x16 is a needle for leather and similar material with a cutting tip
There are a lot of different leather tips depending on how you want your seams to look like.
@Constabulary is correct.  You will want to use a 135x17 needle for fabric as it has a rounded point to separate the fibers when the needle goes through. Using a 135x16 on fabric can result in fraying along the stitch line as it will cut the fabric to make a hole.  If I am sewing fabric to leather, I use a 135x17 as it will sew the leather but not harm the fabric.
http://www.bound2please.com
Sewing machines:  3 - Sunstar 590BL, Artisan Toro 3200, Juki LK-1900HS, Juki DDL-8500-7, Juki DDL-5550N, Pfaff 138-6/21, Pfaff 546-H3, Pfaff 335-H3, Adler 221-76, Singer 144WVS33, Singer 29K-51, Siruba 747B
