Members JudyB Posted May 1, 2020 Members Report Posted May 1, 2020 (edited) I just got a new-to-me Sailrite Fabricator. It's used, but virtually like new. The prior owner still had almost all the original needles that came with it originally. I will be using it for mostly boat upholstry, boat accessories, and boat canvas. I'm wondering what the machine head is based on. Are there feet that will work available from somebody other than Sailrite? Can someone recommend a good source for zipper feet, binders. I'd really appreciate any background information on the machine, and tips on supplies. https://www.sailrite.com/Sailrite-Fabricator-Sewing-Machine-in-Power-Stand-with-Workhorse-Servo-Motor Edited May 1, 2020 by JudyB Quote
Moderator Wizcrafts Posted May 1, 2020 Moderator Report Posted May 1, 2020 A close-up look at the head shows that it uses standard Singer 111 compound feed walking foot machine feet. They are sold everywhere industrial sewing machines are sold. The same feet are used on Consew, Juki and dozens of other brands that are based on the Singer 111w155. Note: This machine doesn't use the feet from the smaller portable Sailrite machines. Those are only dual, top/bottom feed machines that have specialized feet with teeth on the bottom. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Pintodeluxe Posted May 1, 2020 Members Report Posted May 1, 2020 Like Techsew, Tacsew, Yamata and several other badged names. Most are not triple-feed style machine. They have the feed dogs and the walking foot mechanisms, but not the needle feed. Quote
Moderator Wizcrafts Posted May 1, 2020 Moderator Report Posted May 1, 2020 4 hours ago, JudyB said: I'm wondering what the machine head is based on. I'd say it is very similar to a Consew 206RB-5. The bobbin is on the left end, accessed by sliding the bobbin access cover plate to the left. It uses M style bobbins like the 206 and has the same needles and presser feet. One difference is that the Fabricator is optimized for sewing canvas, vinyl and Sunbrella, not leather. The maximum thickness is about 1/8 inch less than the Consew 206. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Tejas Posted May 1, 2020 Members Report Posted May 1, 2020 Wizcrafts seems to be correct. According to the following Sailrite chart, the Fabricator is a compound walking foot machine. https://www.sailrite.com/PDF/Straight-Stitch-Sewing-Machine-Comparison-Chart.pdf Quote
JJN Posted May 1, 2020 Report Posted May 1, 2020 (edited) @JudyB, from the casting, it looks like it is based on the Mitsibushi LY2-3300. It may actually be made by them. Sailrite changed the balanced wheel and maybe some other parts. Edited May 1, 2020 by JJN added photo Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
Members JudyBSails Posted May 2, 2020 Members Report Posted May 2, 2020 Thank you to all who replied and shared their knowledge. I’ve been reading zillions of posts on this forum and learning a lot. I found more info online at Sewinggold.com . The head looks identical to the Tacsew 111w-155, which in turn is built by Typical. From https://sewinggold.com/product/tacsew-t111-155/ : “Tacsew sold their industrial line to Consew so they will no longer be distributing industrial sewing machines. The majority of their machines were based on the brand Typical. The T111-155 is the same as the Typical GC6-7-D which we sell.” More info on the Typical GCG-7G, from https://sewinggold.com/product/typical-gc6-7-d/ : “ Specifications Speed, Max (S.P.M.): 2500* Clearance Under Foot: 1/2" (13mm) Needle Bar Stroke: (37mm) Stitch Length, Max.: (8mm) Needle: 135 x 17 and 135 x 16 for leather Bobbin - Metal: 18034 - Pre-wound : M Hook: Large Horizontal Rotary Workspace: 10 5/16" (260mm) Bed Size: 7" x 18-7/8" (178 x 475mm) Stitch Type: 301 *Speed depends on thread, material and operation. Applications For sewing medium to heavy-weight material such as leather, vinyl, upholstery, synthetics, canvas and various coated and laminated products Designed for stitching such products as auto, boat and furniture upholstery, tarpaulin, covers, sails, tents, camping trailer covers, awnings, umbrellas, tops, bags, luggage, handbags, travelware accessories, sports and camping equipment, wearing apparel, outdoor clothing, canvas shoes, slippers, orthopedic appliances etc Features Long stitch - (8mm) Large bobbin. Bobbin can be changed without removing article being sewn Thread release finger (for heavy thread) High presser foot lift - 1/2" (13mm) Auto Lubrication All gear driven hook mechanism. Large horizontal axis hook Adjustable reverse stitching can be same length as forward stitch Simple adjustment permit raising and lower of the center foot which allows for sewing different thickness of materials and thus assures positive stitching Walking feet, needles and other attachments interchangeable with most other brands walking foot machines Feet can be changed for special operations Standard attachments easily installed Compound feed, walking foot mechanism insures even feeding of material Locking stitch regulator prevents changes in stitch length from vibration I’ll edit this post later to add pictures; I’m using a tablet without storage right now and can’t upload pics. Judy Quote
Members Tejas Posted May 2, 2020 Members Report Posted May 2, 2020 Judy, You've probably already found the Sailrite pdf and video information. In case not, try the following query in google. sailrite fabricator manual site sailrite.com Quote
Members JudyBSails Posted May 2, 2020 Members Report Posted May 2, 2020 (edited) 20 minutes ago, Tejas said: Judy, You've probably already found the Sailrite pdf and video information. In case not, try the following query in google. sailrite fabricator manual site sailrite.com Yes, thanks, I am very familiar with Sailrite. I have owned one of their portable Ultrafeed LZ for over 10 years. It’s a slow machine, and the bed is small, but it is a real workhorse. (The LZ is zigzag and straight stitch., optimized for sailmaking, canvas and vinyl work) Sailrite’s free lifetime technical support is fantastic. They offer video and phone support. For example, recently the bobbin winder stopped working completely. I called to request support. They asked me for a description of the problem and put me in the support queue. 15 minutes later they emailed me a link to a video on how to fix the exact problem I had described. The video was very detailed and easy to follow. The fix and adjustment went smoothly the first try. Personally, I have found find their aftermarket support was worth the premium price on the front end. Edited May 2, 2020 by JudyBSails Quote
Members JudyB Posted May 3, 2020 Author Members Report Posted May 3, 2020 (edited) I couldn't add pics to my earlier post, so here they are: The Sailrite Fabricator, Typical GC6-7-D, and the out-of-production Tacsew 111W-155 Edited May 3, 2020 by JudyB Quote
