Members DavidMillsSaddlery Posted May 17, 2020 Author Members Report Posted May 17, 2020 Yes, that’s what it took, moving the bottom out further! I received the manual yesterday, and should have the video that Tony Luberto makes within a day or two… Then I won’t have so many silly questions for y’all! Quote
RockyAussie Posted May 17, 2020 Report Posted May 17, 2020 13 hours ago, CowboyBob said: Your right & that is what Turbo needs to do get the bracket out more @ the bottom so it shortens the foward stitch.,some machines feed longer in reverse THEN you shim the top. Thanks Bob. I am now thinking it may be a good improvement if the stitch length indicator plate had a V section in the middle when cast in order to allow the plate to swivel in and out and thereby allow precise adjustments if needed . It probably would need a spring behind the screws as done in the shuttle race body or perhaps a couple of small O rings to stop any loosening off. That would be something an operator could do quite easily without any complicated instructions and perhaps avoid the need to send machines back etc. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
