Can I adjust the speed or pressure of the foot pedal on my Singer 16-188? It goes from nothing to full speed ahead and there isn't a middle ground.  If anyone has a suggestion on how to adjust it, I would greatly appreciate it.
You can go to the singer web & DL the manual. If it can be slowed it should show you how
You most likely have an old outdated clutch motor. I would replace it with a new servo motor and add a speed reducer.
Do a forum google search like this:
https://www.google.com/search?q=servo+speed+reducer+site%3Aleatherworker.net&ie=utf-8&oe=utf-8
lots of different solutions in terms of speed reducers. Some DIY some out of the box from sewing machine dealers... lots of options.
Edited by Constabulary
@DeeDesign  With the old clutch motors, you need to slip the clutch like you do with a car with a standard transmission.  Takes practice to be able to regulate the resulting speed.  For me, I would get a servo motor which is variable speed.
Also I moved this to the Leather Sewing Machine area.
Tom
