Members Laurajane Posted July 8, 2020 Members Report Posted July 8, 2020 Hi! I just received my new sewing machine and have spent the last few hours getting acquainted with it. I have read the manual but I can not find what this dial is for. Everything is pretty straight forward but this dial has me scratching my head. I have googled to no avail. Some machines seem to have it, others dont. So please can someone soothe my curiosity and explain what it is! Quote
Members Constabulary Posted July 8, 2020 Members Report Posted July 8, 2020 (edited) we do not know what brand or machine model you have but I´m pretty sure it is mentioned in the manual. Afaik it is for adjusting the foot height. Edited July 8, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Laurajane Posted July 8, 2020 Author Members Report Posted July 8, 2020 (edited) 22 minutes ago, Constabulary said: we do not know what brand or machine model you have but I´m pretty sure it is mentioned in the manual. Afaik it is for adjusting the foot height. Hi. Thanks for your reply. It's a Eagle 1541s which I think is a replica Juki. Would the foot height adjustment be different than foot pressure? I have an old adler that only has half the knobs and dials this new one has lol. I guess I could have a play with said dial but dont want to mess up any settings. The diagram in the manual doesnt show that dial it just mentions a rubber bung which must be underneath it. Edited July 8, 2020 by Laurajane Added more images Quote
Members Silky Posted July 8, 2020 Members Report Posted July 8, 2020 (edited) https://sunny-sewing-machines.myshopify.com/blogs/sewing-machines/juki-dnu-1541s-vs-thor-gc1541s Edited July 8, 2020 by Silky add link Quote
Members Laurajane Posted July 8, 2020 Author Members Report Posted July 8, 2020 26 minutes ago, Silky said: https://sunny-sewing-machines.myshopify.com/blogs/sewing-machines/juki-dnu-1541s-vs-thor-gc1541s Ah ha! Thankyou! That's brilliant! I shall have a play around with that tommorow! Thanks so much for letting me know. Quote
JJN Posted July 8, 2020 Report Posted July 8, 2020 This dial adjusts the STEPPING height of the walking feet. If you are sewing material with constant thickness, you can keep is set low. It doesn't matter how thick, just that the thickness is consistent. If you are sewing a project that has large differences in thickness like sewing a seam with a thick strap or thick seam in the middle, you will want to set this dial to a higher value so the walking feet can step over the change in thickness in mid-seam. If you don't increase the step height, the walking foot will push the strap out of position or stop feeding the material at a thick seam. Think if it as shuffling your feet when you are walking or high stepping like you are marching or climbing stairs. I have the Juki your machine is copied from. I don't have the dial (I wish it did), but can make the same adjustment by loosening a nut and moving a slide up or down on the back side of the machine. The dial allows you to change this adjustment 'on the fly' as you are sewing. Congratulations on the new machine! Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
