ivan7342 Report post Posted August 2, 2020 Hello guys, I'm running into an issue, maybe i can get some solution here. After dye i applied water based laquer, already gave it 5 light coats and it's still bleeding, so i thing there are 2 issues, first, it's not sealing as much as it should, so down the way it can affect things it get in contact with, also, each coat i gave, the mix of laquer and dye that results on the clot could be changing a bit the color of the piece, even if slightly... I was thinking maybe to put the laquer in some spray dispersion pulverizer and use that instead of a clot In the picture you can see the color on the piece and the color that ends on the clot i'm running the laquer with. Thanks. Quote Share this post Link to post Share on other sites
ScottWolf Report post Posted August 2, 2020 Question about the item. Did you wipe/buff the item you dyed down once it was dry, to remove the excess dye, before applying the sealer? Quote Share this post Link to post Share on other sites
ivan7342 Report post Posted August 2, 2020 Yes, i wiped the excess dye the day before, let it overnight since it was late already. Quote Share this post Link to post Share on other sites
Dwight Report post Posted August 3, 2020 2 hours ago, ivan7342 said: Yes, i wiped the excess dye the day before, let it overnight since it was late already. That wasn't the question . . . did you BUFF the item after it dried??? There are a few dyes . . . few and far between . . . that do not need a serious buffing after they dry. The rule of thumb is sorta . . . the darker the dye . . . the more you buff . . . and if you use USMC Black . . . you will never buff off all of the loose pigment. It is the loose pigment that is giving you the problem. Take a white terry cloth wash cloth from your wife's stash . . . don't get caught . . . lay down whatever you have made . . . and buff that thing like you are trying to burnish a brass bell. Then . . . put the next coats of laquer on with a brush . . . preferably a cheap bristle brush like the 50 cent ones you get at Harbor Freight. You will probably have your problem cured by then. May God bless, Dwight Quote Share this post Link to post Share on other sites
ivan7342 Report post Posted August 3, 2020 Thanks!! I will try that today!! Quote Share this post Link to post Share on other sites
