Members Memphis514 Posted September 22, 2020 Members Report Posted September 22, 2020 OK, if i use an airbrush to apply Fiebings Pro Dye to a project, what is the best/most reliable/cost effective cleaner to run through the airbrush when i am done? TIA -- chris Quote
Members Grumpymann Posted September 22, 2020 Members Report Posted September 22, 2020 I use Denatured alcohol then water now a days. before I used windex (without amouna ) cut 25/ 75 with water for a fast clean. with a brake down and swab clean about once a week when I do heavy use week. Quote
Members Alaisiagae Posted September 23, 2020 Members Report Posted September 23, 2020 Depends on the components of the airbrush. My dad has some all-metal air gun brushes and after we used wood stain and varnish with it, he cleaned it out by running acetone through it. Acetone is rather harsh and would not be good if your air brush has any plastic pieces. Grumpyman's suggestion would work, though I wouldn't soak any platic parts in alcohol for very long, as there are chemical compatibility issues - especially with acrylic, that stuff is not good at resisting alcohols (isopropanol or ethanol, for instance) and will be damaged easily. You could look up the SDS files of commercially sold cleaners (such as from Angelus?) to get some info about the chemicals in those. But, I'm afraid I'm all out of advice, because I personally don't use an air brush with dye for leatherworking. Quote
Members Rahere Posted September 23, 2020 Members Report Posted September 23, 2020 It would be easier, under these instances, to use a venturi brush, which creates an airflow across the mouth of the bottle to create a vacuum sucking its contents into the flow. All you'd have to clean then is the cap of the bottle. Quote
Members billybopp Posted September 23, 2020 Members Report Posted September 23, 2020 After spraying dye, I run some isopropyl alcohol through my airbrushes. If I won't be using it again, it gets disassembled and cleaned in a cheap ultrasonic cleaner that I had lying around. - Bill Quote
Members Memphis514 Posted September 25, 2020 Author Members Report Posted September 25, 2020 On 9/22/2020 at 5:02 PM, Grumpymann said: I use Denatured alcohol then water now a days. before I used windex (without amouna ) cut 25/ 75 with water for a fast clean. with a brake down and swab clean about once a week when I do heavy use week. On 9/23/2020 at 4:25 AM, Alaisiagae said: Depends on the components of the airbrush. My dad has some all-metal air gun brushes and after we used wood stain and varnish with it, he cleaned it out by running acetone through it. Acetone is rather harsh and would not be good if your air brush has any plastic pieces. Grumpyman's suggestion would work, though I wouldn't soak any platic parts in alcohol for very long, as there are chemical compatibility issues - especially with acrylic, that stuff is not good at resisting alcohols (isopropanol or ethanol, for instance) and will be damaged easily. You could look up the SDS files of commercially sold cleaners (such as from Angelus?) to get some info about the chemicals in those. But, I'm afraid I'm all out of advice, because I personally don't use an air brush with dye for leatherworking. On 9/23/2020 at 6:51 AM, Rahere said: It would be easier, under these instances, to use a venturi brush, which creates an airflow across the mouth of the bottle to create a vacuum sucking its contents into the flow. All you'd have to clean then is the cap of the bottle. On 9/23/2020 at 7:53 AM, billybopp said: After spraying dye, I run some isopropyl alcohol through my airbrushes. If I won't be using it again, it gets disassembled and cleaned in a cheap ultrasonic cleaner that I had lying around. - Bill thank you for all the helpful ideas...it is appreciated Quote
